Suspension setup advice needed - Triumph Forum: Triumph Rat Motorcycle Forums
Closed Thread
Old 06-11-2006, 08:36 AM   #1 (permalink)
I tried to Google, I tried to search here to not bug ya'll unless I had to...
I ride a 2005 Bonnie, mainly to work and back and as much as I can on the weekends. I am 6' 220 lbs. and would qualify myself as a bit more aggressive rider than average. Every once and a while my gf hops on with me and with my weight and her, I can tell I need to be on a stiffer setting...even though she is half my weight.
I want to adjust my rear shock (until I can replace it and the front springs) but I have no clue how to do it.
Can anyone advise me on what adjustments are available on the rear shock and what may be a good setup for my weight?
I am on the second from softest setting (I think) but I admit, I have no clue how to change this setting. Do I have to loosen that bolt to turn the shock to the stiffer settings?
Thank you so much to anyone who has the time to look and comment on this.
dawgfan is offline
Old 06-11-2006, 11:45 AM   #2 (permalink)
There is a small tool that should have come with your bike. It is a few inches long and kind of resembles a large wrench. Throw it on to the lower end of your shock, hooking the two edges and turn. I wish I knew all the technical terms but I don't. It took me a few seconds to figure it out, and I was done. I went from (2) to (3) and it made a nice difference in handling. A bit more rigid on the bumps, but I like the compromise. I am having a local tech replace my fork springs with Progressive springs and I have Progressive 412's for the rear shocks on order. The small adjustment I made on the stock shocks did make a difference though. At least until the new stuff comes in.
dharmabum is offline
Old 06-11-2006, 12:27 PM   #3 (permalink)
It's called a spanner - and AFAIK one did not come with my Bonnie.
derek985 is offline
Old 06-11-2006, 12:51 PM   #4 (permalink)
Maybe the Spanner fairy dropped it in my kit while I was walking out the dealership doors. Is this something that is standard or it's up to the dealership what they throw in? Also, where is a cheap and quick place Dawgfan can buy one?
Old 06-11-2006, 03:21 PM   #5 (permalink)
Favourite Bike: 04 Bonnie black
A strong grip will turn the shocks,as will channel locks and a rag,a bent screwdriver,ground to fit the shallow hole on the collar,or even the allen wrench "toolkit" will turn it.
rodburner is online now
Closed Thread
Suspension Setup RoadBuilder Sprint Forum 19 06-18-2007 10:58 PM
Suspension setup- Static Sag greenman Tiger Workshop (archive) 1 07-09-2006 11:59 AM
1050 S3 - Race Day Suspension SETUP gstar Speed Triple Forum 11 06-13-2006 06:30 PM
Suspension setup for Adventurer? Help! Brooke Hinckley Classic Triples 1 03-30-2006 02:24 PM
Speed Triple Suspension Setup hooligan2001 Speed Triple Forum 1 07-13-2004 10:39 AM
