DandD pipes and center stands - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Closed Thread
Old 06-11-2006, 07:16 AM   #1 (permalink)
mikedodger
After installing a new set of D and D pipes onto '06 Bonnie - i noticed that there is no longer a stop/buffer provided. I'm looking for any recommendations - I was thinking of extending the existing bracket on the stand to contact the swing arm, but that might get a little long! :???:
Old 06-11-2006, 08:01 AM   #2 (permalink)
Favourite Bike: 1972 Suzuki TM 250
Loxpump's Avatar
I have the same problem with the burgess style mufflers I recently put on. If anyone has a method/fix for this that works, some pics posted would be a great help. I have a 2001 Bonneville. I was thinking of a small bracket bolted on the bracket that the center stand pivots from that would act as a stop for the stand.
Stop Global Whining!
Semper Fi!
Loxpump is offline
Old 06-11-2006, 09:18 AM   #3 (permalink)
A bit tacky I realize..... but it works:
I used a little leather Mag Light (flashlight) holder, hid the worm-screw mechanism of the pipe clamp I used to tighten it to the center-stand, and shot it all with some flat Black paint.
The resulting leather and worm-screw mechanism in the flashlight pouch area silences the clang of the center-stand banging against my pipe.
- 'Rider' -
Click here for a view of my Member's Album.
FattRat is offline
Old 06-11-2006, 09:29 AM   #4 (permalink)
mikedodger
Thanks for the ideas, but there's another problem - the stand will actually also hit against the chain and the chain has the correct tension.
- My other idea is to weld a small block of steel stock as a stop on the center stand bracket.
Old 06-11-2006, 04:47 PM   #5 (permalink)
HiVel's Avatar
I used a furniture level adjuster-1/4" thread and adjustable with a rubber bumper that comes on the end. I drilled a hole in the centerstand and tightened it so the stand would not hit the chain on the other side. I glued a square cut piece of leather (old belt) to the bumper , sprayed it black and it really is not noticeable and works great for a year now.
2007 Tiger "Old Blue"
2004 Thruxton "Big Red"
2006 Sprint ST ABS "The Blue COW"
HiVel is offline
Closed Thread
Rear Stands vs. Center Stand ddmhnl Twins Talk 5 05-18-2006 12:02 PM
center stands Garyhjd Hinckley Classic Triples 12 01-25-2006 10:11 PM
center stands Speed Triple Forum 7 10-01-2004 02:14 PM
center stands shootist Sprint Forum 3 08-06-2004 11:59 PM
center stands Sprint Forum 5 05-31-2004 10:16 AM
