Old 06-02-2006   #1 (permalink)
Anyone here using heel toe shift w/foot boards? Doesn't seem to be all that compatible, or is it me?
Brit26
Brit26 is offline   Reply With Quote
Old 06-03-2006   #2 (permalink)
IMHO the Triumph is not suited for that set up, although it may be fine for the Rocket certainly not for the Bonnie. That set up was great on my Harley Heritage and Electra Glides. I would never consider for my Goldwing or Bonnie.
"If you think you can or if you think you can't, you're right."
-Henry Ford
chazzman is offline   Reply With Quote
Old 06-03-2006   #3 (permalink)
Favorite Bike: 06 Scrambler
The heel toe shifter does not work well with the floorboards or for that matter with out boards. You can modify it by bending the back portion in to make it parallel to the shift rod and cut the rear (heel shift knob) knob down to about 3 rings of the rubber. You can also remove about 1/4" of metal from the "half moon" slot at the top of the slot to give more back postioning of the lever and then it is fine. It is a lot of trouble but if you like/enjoy the heel/toe shifter it workd great.
larryshep is offline   Reply With Quote
Old 06-04-2006   #4 (permalink)
Larry,
Did surgery on heel toe shifter and it works great, thanks for the advice.
Brit26
Old 06-04-2006   #5 (permalink)
Brit26,
Great, glad you were succesful in the mod. I have done 7 of them I think, lost count. To me up shifting is quicker and more positive and you now have room on the board for your entire foot.
I also cut down the length of the front shift peg as it does not have to be as long as stock as your toe just pushes down on it now.
Old 06-04-2006   #6 (permalink)
bonnevillebilly's Avatar
Can some one post a pic. I have been looking for some
kind of forward controls or maybe just some forward foot
rests. because some times on long trips my legs feel like
they are cramping up no me and, I walk a little funny when
I get off the bike.
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
foot boards skull Modifications & Workshop Talk 2 04-23-2007 05:57 AM
Foot Boards vs Pegs gsmitty The Rocket Science Forum 5 08-25-2006 11:53 AM
Rivco foot boards Crackerjim The Rocket Science Forum 12 04-07-2006 07:27 AM
Heel-Toe Shifter mtnwinds The Rocket Science Forum 8 11-19-2005 08:01 AM
Longer shift lever/heel-toe shifter? UJMrider Hinckley Classic Triples 16 04-07-2005 02:52 PM
