BikeBandit
Old 05-31-2006   #1 (permalink)
Loxpump's Avatar
Has anyone successfully bobbed their rear fender? It appears to be very light gage steel. Could a careful cut do the job and not ruin the paint? The cut end would be partially hidden under the taillight and license plate and not easily visible. There doesn't seem to be any lip on the fender now.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 05-31-2006   #2 (permalink)
Favorite Bike: 05 Black Speedmaster
No matter what cut method you choose, you would almost certainly have to repaint the fender.
Old 06-01-2006   #3 (permalink)
Favorite Bike: 02 Bonneville
Other Motorcycle: 05 SV650S
I'd get a GRP replacement fender from e.g. mototwin. And then chop it and paint it if neccesary
02 Bonneville - Originally green/silver , now going black. Dual headlights/black fly screen. Emgo Shortys, rubber bellmouth, Uni, AI, 120/42, thrux needles, no shims. Thruxton seat and low bars. Ikon 7614 shocks, renntec rack. A Bonnie Cafetourer..
ivar is offline   Reply With Quote
Old 06-01-2006   #4 (permalink)
I chopped my rear fender. it was reall easy. Did it with the 4" grinder with a cutting wheel on it. Cleaned up the edges and put a piece of black door edge trim around the edges. I didn't want to repaint yet. the black trim actually looks pretty good and protects the edges. You can get the trim at pep boys.
andyhinman is offline   Reply With Quote
Old 06-01-2006   #5 (permalink)
Loxpump's Avatar
I suppose you could hand paint some pinstriping along the cut edge.
Semper Fi!
Old 06-01-2006   #6 (permalink)
I know I've read in this forum awhile back that guys have bobbed the rear fender using nothing more than masking tape and a dremel with a cutoff wheel. And I think the only paint they did was to cover the bare metal exposed from the cut. If you search around the old threads, you can probably find more discussion on it.
kdlutes is offline   Reply With Quote
Old 06-01-2006   #7 (permalink)
i think "rear fender bob" had a personal on craigslist. :-)
So long, and thanks for all the fish!
DrEnglish is offline   Reply With Quote
Bob Job, Bonnie Rear Fender jerseyjeff Twins Technical Talk 6 11-10-2007 09:21 PM
fender bob. . . what do you use to cut? neuroboy74 Twins Technical Talk 10 10-16-2007 02:34 PM
Rear fender bob fender Twins Technical Talk 10 06-21-2007 01:30 PM
Should I just bob the rear fender? InfX708 Twins Talk 7 10-06-2005 01:46 PM
Fender Bob and Hard Bags Kieran Sprint Forum 4 05-05-2005 10:05 PM
