Old 05-27-2006   #1 (permalink)
fuelish
[ This message was edited by: fuelish on 2006-05-31 06:34 ]
Old 05-28-2006   #2 (permalink)
Without going through this entire list let me just ask you, if the shim puck is to thick and holding the valve open, how would you expect the engine to build compression? Vegas
Asmith is offline   Reply With Quote
Old 05-28-2006   #3 (permalink)
Assumimg you are the original owner, I am VERY curious as to what Triumph will do to help you out even though you're beyond the warranty. What does your dealer say? I mean let's face it, you have a very extraordinary problem here.
Do keep us posted and good luck
CC
PA-guy is offline   Reply With Quote
Old 05-28-2006   #4 (permalink)
fuelish
i changed out the puck on first assembly to get the correct clearence. i fixed every problem i could find was very meticulous and clean about assembly even though cam bearings and journals are obviously shot. triple checked pistons, rings,bore,gaskets .....valves are sealing.......and yet poor compression in that cylinder..???? as for the dealership i have only inquired about parts cost,, have not brought this issue up since warranty is expired.
Old 05-29-2006   #5 (permalink)
If the valve was open all of the time it more than likey came in contact with the top of the piston and is now bent. Bent valves do not seal real well. Vegas
Old 05-29-2006   #6 (permalink)
I think you are scaring these people. No one seems to want to talk with you! Vegas
Old 05-29-2006   #7 (permalink)
Favorite Bike: 2004 Bonneville America
Bryan's Avatar
Other Motorcycle: 1976 T140V {Bonneville}
Extra Motorcycle: 68'YCS1E,71'CT90,82'XL80
What year is your bike fuelish?
Bryan is offline   Reply With Quote
tba-golfer down! tba-golfer Biker Hang-Out 46 03-24-2007 10:57 PM
TBA pulling to the right? HELP!!! dseely Twins Technical Talk 6 11-17-2006 03:28 PM
Some pics of My TBA Matt_the_Rat Twins Technical Talk 11 10-31-2006 10:05 PM
Staintunes for TBA? c9d9 Twins Technical Talk 6 09-15-2006 02:20 PM
More TBA Golfer's Beautiful TBA - PICS Ridge Twins Talk 6 07-09-2006 08:45 AM
