OK,...I'll try.
When the air/fuel mixture explodes, it does so at reasonably fixed rate,...BUT...(here is where it gets tricky), the parts, are spinning faster and faster as revs increase. Therefore the spark must be introduced earlier, in the stroke to get the maximum power from the air/fuel mixture. There are many other things that can have an influence on the rate of advance or "curve" of your spark advance, such as the overall flow or breathing of your motor. I believe some of the boxes you mention with a modified curve have a higher maximum rpm before the limiter as well.
Hope this helps. It's basic, but gets you on the right track.
Tony
