» Links |
05-24-2006
250 Grand Prix Favorite Bike: Triumph Bonneville 07
Posts: 103 Other Motorcycle: Kawasaki KZ 440 - gone
OK, I'm still a Triumph owner wannabee - and IT'S KILLING ME! Anyway, I know there have been many comparisons between the Bonnie Standard and Bonnie T100. I know a standard can be brought up to spec with a T100 for around $700 and change. Now, of course, the 790 CC engine is the one thing that can't change. So here is my question. Would a newbie rider such as myself even care about the difference in CC's? I was eyeing a Goodwood? Green Bonnie at the dealers yesterday and thinking (In the interest of saving some money) that I could be very happy with this bike. I'd just add the kneepads and probably Tachometer. Oh, another question when the Tach is added is it the same as the T100 or a little different?
Man, I can't wait to buy a bike but finances aren't there yet and wife would kill me. But I know it will happen some day and I'll be a true member of this prestigious club.
Thanks for listening to my lament you lucky owners. :razz:
World SuperBike Favorite Bike: 2005 Bonneville T-100
Tomster,
It's a lot more then a tach and knee pads that as far as the bikes go....
But as a new rider, the 790cc has more then enough power for you to have a blast with.
Also, as far as the engine goes, the 790's actually has a higher "ceiling" then the 865's if you plan on doing major engine work. You will obvioulsy get more benefit out of a 904 kit, plus you can get a pro-com rev limiter and Thrux needles too....
With that said...I love my T-100!
05-24-2006
whats this about a higher ceiling? haven't heard that one. also, can you not add thruxton needles to the T100?
05-24-2006
The cc's are only part of it. The T100 i believe has different cams and develops it torque at a lower RPM, which IMO is worth considering. My 05' speedmaster has the lowest point of max RPM of all the twins, (max at 3500 i believe) and i can tell you that low down torque is a huge bonus as to the way the bike feels. Not to mention bonnies are geared low, so the more low down torque the easier the bike will handle a larger front sprocket to gear up a bit. How much you'll noticed between the bonnie and T100 i don't know. But the T100 is second onlt to the speedmaster in low down torque. if it were me i'd definatly go with the T100 for all reasons.
[ This message was edited by: dazco on 2006-05-24 13:23 ]
05-24-2006
As far as I know the T100 has Metzeler tyres fitted as stock from 05, and you get reach adjustable brake and clutch levers
If you add the tacho to a basic Bonnie it's not the same as the T100 one
The main differences are tyres, tacho, paint, levers, chrome engine casings
865cc gives you slightly more power than the 790
Oh and the T100 has an 18 tooth drive sprocket as stock
Good luck with whatever you choose
[ This message was edited by: EnglishBaz on 2006-05-24 13:25 ]
Cheers People
Bazza
I love my bike cos it\'s a bonnie and its beautiful and I waited years for it and it sounds..............FANTASTIC!!!
05-24-2006
DJ,
The 865 already comes with Thrux needles and an 8000 RPM max as opposed to the 7400 max on the 790.
But if you put a 904 kit on both bikes, you will have a two bikes with 904cc engines, but you can put the 865 needles on the original 790, plus add a Pro-com to get a RPM max of 8400 instead 8000, along with having the 790 cams which I believe are more aggressive.
Maybe a higher ceiling is the wrong way to put....maybe, more bang for your mod buck is a little better. A 904 kit for an 865 is really not that good of a deal...that's a lot of cash for a 39cc gain.
When you NARK the bikes, you get more high end power....that is better suited for the 790 cams.
[ This message was edited by: Panthermark on 2006-05-24 13:30 ]
05-24-2006
Differences:
865cc engine (instead of 790cc) - new for 05
Knee pads
Chrome Engine covers
Higher rev limiter - new for 05
Paint scheme
Adjustable clutch and brake levers - new for 05
18T sprocket (instead of 17t) - new for 05
Tachometer
Thrux needles - new for 05
Triumph Eyebrow Tank Badges
05-24-2006
Formula Extreme Favorite Bike: 05 T100
Posts: 608 Other Motorcycle: Don't need another one!
Really? I think you'll find the tacho kit supplied by Triumph contains the same tacho as fitted to the T100, along with the alloy fascia plate and different trip meter reset knob for the speedo.
Paul.
Herts. UK
Opal & Tangerine 05 T100 (865cc)
(Previously Ducati Monster S4 and numerous UJMs)
05-24-2006
thanks panthermark.
back to the original posters question... my vote is to get the 790 and use the money saved towards new silencers. those are by far the best addition i've made to my bike. the 790 has more power and speed than i will ever need.
in the end either decision will be a good one that you will be happy with, after all, you're getting a Triumph!! congrats man :-D
05-24-2006
SuperStock Favorite Bike: 2006 Bonneville
Posts: 244 Other Motorcycle: 1953 BSA A7
I think you will be satisfied with any of the bikes; the difference is not that big. I use to say that it is about 10 % when it comes to cubes, power, equipment – and price.
I bought the T100 because I wanted the bigger engine-just in case and the two-coloured tank and the rev counter. The tank is even hand pin-striped, by Neil.
Whatever you are, be a good one. Abraham Lincoln
