Thanks for the info guys.
Mike, I was trying to use the brace from an old SB kit that I had, looks like I'll use one from your ARkit.
When I took the old CVK carbs off I left the TPS connected and untouched. Do I need to reconnect it when using the CR carbs or can I just leave it off all together. If I do re-connect the TPS what happens when I want to use the stock CVK carbs again can I re-set the TPS back to standard?
Regards
Oliver Cole
www.mototwin.com
