Progressive Insurance
CycleGear.comAnnitori DistributingbritishcustomsSpringfield ArmoryMotorcycle.com Classifieds!SportbikeTrackGearAmericanMotorcyclistAssociationTrident-Exhausts.comAdvanstarMotorcycleShowsShopTriumph.comMotorcycle.com
Old 05-21-2006   #1 (permalink)
RT
Favorite Bike: 06 Tang & Opal T-100
RT's Avatar
Other Motorcycle: 06 Tiger Caspian Blue
Extra Motorcycle: 07 America Black & Chrome
Will hit 500 probably by end of week. Have appt at dealer for 1st June. After seeing the price of 15-50 at dealer yesterday think I will change my own oil before service.
Oil was $53 and change for 1 gallon.
Will go with Mobil 1 V Twin 20-50.
Anyway, the washer on the drain plug. Do you change every time? What size washer do I need to get?
Is it a aluminum washer?
Confused and Prone to Wander
RT is offline   Reply With Quote
Old 05-21-2006   #2 (permalink)
i've done 3 changes with the same washer.
Old 05-21-2006   #3 (permalink)
jimmything's Avatar
Just changed my today. First one at 636 miles. Used same washer. Looks to be aluminum and should last many times. Went with Castrol full synthetic 10w-40. :-D
2006 black Speedmaster with Epco pipes, 130 mains, snorkel and AI removed, UNI filter, drilled airbox, Corbin solo seat.
"Ride it like you stole it"
jimmything is offline   Reply With Quote
Old 05-21-2006   #4 (permalink)
I get a new one. Where I buy the oil he gives it to me for free. That said there is probably nothing wrong with reusing
Darcy.
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 05-21-2006   #5 (permalink)
mecscc's Avatar
It is a crush washer, very soft, and you can tell if it has been distorted. Buy one new one and use it to compare with the one coming off. If it is not badly distorted you can use it over several times.
Monte
Monte
"The Old Ohio Preacher Man"
Old 05-21-2006   #6 (permalink)
Favorite Bike: 2008 Victory Kingpin
Silverado57's Avatar
Other Motorcycle: 2006 Victory Vegas
Extra Motorcycle: 2005 Speedmaster (Ret.)
For a couple of bucks go with the new washer.
Kevin
Luceo Non Uro
NJ USA
Silverado57 is offline   Reply With Quote
Old 05-21-2006   #7 (permalink)
DJ
When I buy a filter they include it at the dealership.
DJ is offline   Reply With Quote
Old 05-21-2006   #8 (permalink)
Favorite Bike: 05 Black Speedmaster
The washers are aluminum and can be used several times.
They are the same as some import cars (forget the size)
I bought a bag of 100 for like $20.00. Check them for cracks
when reusing.
Old 05-21-2006   #9 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
It's the same size crush washer as my old '90 Honda Accord uses. I buy a dozen at a time from the Honda mechanic, and they cost me $0.25 each. At that price, I change the washer each time.
Why are you going to take the bike in for the 500 mile service, if you are going to change the oil and filter yourself? Changing oil and filter is about the only service most dealers do at the 500 mile "service". Get a service manual and do the checks yourself that they should be doing and probably won't.
Larry
Larry
Oil Drain Plug Sealing Washer Question div2 Speed Triple Forum 14 06-17-2008 10:37 AM
no drain plug crush washer ?? jerryb Twins Technical Talk 10 10-29-2007 11:50 PM
oil drain plug washer SamaR Sprint Forum 24 08-02-2007 10:04 AM
oil drain plug washer peter_s Twins Technical Talk 8 07-08-2007 09:02 PM
oil drain plug jeffro232 Speed Triple Forum 5 07-08-2005 12:05 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
