Old 05-18-2006   #1 (permalink)
When adjusting the chain for slack, does it matter whether it is on the side stand or on a lift? It does not seem to me that load should make a difference when adjusting given the pivot of the rear arm should keep the relation between the sprockets the same - but wanted to make sure. Thanks.
Tom
Tom
2005 Thruxton
momini is offline   Reply With Quote
Old 05-18-2006   #2 (permalink)
Owner's manual says on the sidestand.
Michael D. Rodriguez
RoundSlide is offline   Reply With Quote
Old 05-18-2006   #3 (permalink)
mecscc's Avatar
Its easier and potentially more accurate with a lift or a center stand. You can spin the chain and look for stretched sections, check the sprockets for wear easier and, if you have to adjust it, the wheel moves easier. Plus you can line up the chain easier either by sight or with a stretched string. On the side stand you have to assume that the current alignment is correct. That is often not a good assumption, particularly given the poor quality of some dealer setup these days. The guys that are assigned to put together bikes are not often the top mechanics.
Can you do it on a side stand? Sure. But I wouldn't.
Monte
Monte
"The Old Ohio Preacher Man"
Old 05-18-2006   #4 (permalink)
EnglishBaz's Avatar
I reckon that a centre stand or a lift would be great for spinning the chain to check if any links are seized or stiffening up
but I was taught at my bike school that if you measure the chain with the rear wheel off the ground and then tighten accordingly - when the wheel goes back on the ground the chain will be over tight
so the chain should always be measured and adjusted with the wheel on the ground
Cheers People
Bazza
I love my bike cos it\'s a bonnie and its beautiful and I waited years for it and it sounds..............FANTASTIC!!!
EnglishBaz is offline   Reply With Quote
Old 05-18-2006   #5 (permalink)
Thanks for the replies - The manual does say on the side stand, but also says to measure at the point of least play - this strikes me as hard to determine by measuring, move the bike a bit, measure, etc etc. That is why I ask about using my stand.
Tom
2005 Thruxton
Old 05-18-2006   #6 (permalink)
This is one of those situations where a rear/race stand is really convenient, because you can spin the rear wheel but the weight is still on the swingarm.
joeswamp is offline   Reply With Quote
Old 05-18-2006   #7 (permalink)
Of course the manual will suggest you put your bike on it's side-stand...... it doesn't come with a center-stand!
And I too was taught to adjust the chain with the weight it is expected to carry in mind. If I'm running solo, I might ask a buddy to sit on my bike for me so I can check the slack. I might also adjust accordingly if I plan to carry the additional weight of luggage and a passenger....
- 'Rider' -
Click here for a view of my Member's Album.
FattRat is offline   Reply With Quote
Old 05-18-2006   #8 (permalink)
mecscc's Avatar
You have a good point, Baz. I guess I should have said what I do, which is to keep the slack about 1/2 to 3/4" more than the book says so that when back down on the ground it will not be too tight. And, again I should have said this, when I am done I check the chain with the bike fully on the ground.
While I am mentioning what I forgot to mention, let me say that you are always better off with a slightly loose chain than a too tight one. A chain has to be really loose to fly off, but one that is too tight can do some nasty damage to the whole system.
Monte
Monte
Old 05-18-2006   #9 (permalink)
Until you are real familiar with a particular bike, it is always best to go by the book. I measure on the side stand and adjust on the center stand. I have found that the measurement on the center stand for my '03 T-100 is only about 1/8" looser than the measurement on the side stand. I like to run my chain at 1.25" slack, so I set it on the center stand at a little more than 1.25" and it is about where I want it when I measure it on the side stand. The last time I took it to the dealer for maintenance, the mechanic set the chain slack at 3/4"--this is the last time that mechanic touches my bike!
Larry
Larry
Old 05-18-2006   #10 (permalink)
Other Motorcycle: harley Davidson 1983 flht
Extra Motorcycle: enfield,yamaha 650,400rd,
always check your adjustment when you are sitting on the bike. have a friend sit on it if you like.
fine where the chain is most slack and that should be on the bottom side then adjust each side evenly
a 1/8 of a turn one side and an 1/8 of a turn the other
good luck
rtt
[ This message was edited by: runtheton on 2006-05-23 21:10 ]
runtheton is offline   Reply With Quote
simple green to clean chain ricster Sprint Forum 65 09-24-2007 09:25 AM
Keep it simple, check your tires and lube your chain TOMKRILL Twins Technical Talk 10 06-26-2007 04:37 PM
Simple question? lancashirelad Hinckley Classic Triples 5 05-21-2006 03:29 PM
Simple question pigpen955 Twins Talk 7 04-19-2006 09:48 PM
Simple Tyre Question chrisn Tiger Chat 2 05-12-2005 02:52 AM
