I have been having a problem lately, thought someone here might have some ideas...
Heres what happens...While the bike is on and running, everything will suddenly die, just like if you turned off the ignition. If I am moving at the time, the tach acts really weird, surgeing up to redline and above, but the engine is not running those rpms....
I pull over, and very quickly (within 30 seconds to a minute) everything is fine again. Starts right back up, and away we go. Usually it only happens once, then everything is fine for several hundred miles.
I had thought it was a bad connection at the battery, but it happened this morning on a road trip. I stopped, cleaned and tightened the terminals, then it happened again about 50 miles later.
There does not seem to be a common denominator for the outages, it has been both rain and shine, moving and stopped, smooth and rough road. No particular speed, it seems random.
I am going to go through all the connections I can find tomorrow and clean/tighten them, then probably run up to the dealer sometime this week. Hopefully its an easy fix somewhere, the weather is just starting to turn nice and I'd hate to have the bike in the shop!
Thanks.
