As long as you're going to replace the springs, consider the following:
1. remove fork tubes from the triple trees (takes about 15 minutes)
2. turn tubes upside down and pump (compress and extend tube) several times to drain out oil
3. place tubes upside down in a catch can to contain the oil which slowly drains out (takes about 2 hrs). I found some metal powder settled out of the old oil on the bottom of the catch can.
4. fill about 1`/2 with kerosene and pump several times, then invert and pump several times to empty and drain again - I left them drain overnight to get all the kerosene out.
5. fill with 1/2 liter of new fork oil, pump tube several times to fill bottom of tube with oil
6. compress tube fully and measure from top of tube to oil level - should be 120 cm. (Triumph says it takes 488 cc, and 1/2 liter is 500 - the difference is so small you'll never notice it)
7. install new springs with closely wound portion up, reinstall washer and and cap and tighten
8. reinstall tubes and reassemble front end.
Total work time is about 2 hrs (this was th first time I even installed new springs) - most of your time is waiting for old oil and kerosene to drain out.
Hard work may pay off some day, but laziness always pays off right now.
Bill
View my photo album
