Nipple plugs - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleMotorcycle.com Classifieds!Honda Powersports
Old 04-26-2006, 03:42 PM   #1 (permalink)
The rubber plugs that went over the carb and intake manifold nipples were cracked so I replaced them with some I got at AutoZone. The original ones were much thicker. Has anyone else replaced theirs and if so where do you get them. I'm afraid the dealer will want about $4 a piece for them. I bought a package of 6 from Autozone for around $3 I think. It's been a few months. They are cracking now too.
John
vol245 is offline   Reply With Quote
Old 04-26-2006, 03:48 PM   #2 (permalink)
NAPA has some decent ones. Sometimes you can find them at your local farm & home supply or hardware store.
Happiness is a belt-fed weapon
kballowe is offline   Reply With Quote
Old 04-26-2006, 03:50 PM   #3 (permalink)
Mine are doing that as well. I'd be interested in where to get some right sized ones as well without a fancy markup.
Anvil6 is offline   Reply With Quote
Old 04-26-2006, 04:00 PM   #4 (permalink)
Did he say "nipple" ???
Old 04-26-2006, 04:04 PM   #5 (permalink)
I'm still puzzled as to why no one seems to make them from a material that doesn't crack so easy. In the 10 months i've had my bike i've replaced them 3 times. Not that they were leaking, but they were so cracked they looked like they would soon. I'm thinking maybe a piece of silicone sugical tubing with a metal plug in the end too big to fit in the nipple hole would do the trick and last a while. Ohhh.......i said "nipple" too. :-D
Old 04-26-2006, 04:10 PM   #6 (permalink)
Got one from my dealer for $1.83. Part # TRT1241012. The one I received with my AI removal kit started cracking after about a month.
DWIT100 is offline   Reply With Quote
Old 04-26-2006, 04:13 PM   #7 (permalink)
I welded all my nipples shut.
jsdc2005 is offline   Reply With Quote
Old 04-26-2006, 04:14 PM   #8 (permalink)
Don't you just HATE cracked nipples? :roflmoa2:
Old 04-26-2006, 04:16 PM   #9 (permalink)
Not a bad idea. I was thinking of finding a fine thread screw that would fit just right and cut it's own slight threads as i turn it in sealing it off well. Maybe enen a little locktite
Old 04-26-2006, 04:19 PM   #10 (permalink)
You can't do that on the carb nipples :-D or you won't be able to balance them.
John
Vaccum nipple rubber blew off? riron2001 Twins Technical Talk 13 06-28-2007 01:51 AM
Plugs? webonnielad Twins Technical Talk 1 01-26-2007 03:33 PM
Broken spoke nipple BillyRaff Twins Talk 4 04-02-2006 05:58 PM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 11:54 AM
plugs musicman59 Classic, Vintage & Veteran 8 09-19-2005 12:02 PM
