AdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.comBikeBandit
Old 04-14-2006   #1 (permalink)
After a night of looking at stripped down 60's Triumphs on the net, I was amazed on how simple and open the engines look.You can see right through them! How do they even run like that? Next day I woke up with an uncontrollable desire to start taking stuff off my SM. First, I removed the peg hangers...looked better, then i took of the cheese graters and all plastic around them. Then I took out the tool box and all brackets from the airbox removal kit(except carb brace). Now its starting to open up. My only obstacle was the battery box, which I took out and laid the battery in front of the rear tire. Then I bound all the wiring and pulled it up under the seat. You can see straight through to the other side now. Bitchin!
But a couple of issues. First, I mounted the battery flat on its side(according to Yuasa, it should be fine)and secured it with a leather battery strap and rubber mat underneath to minimize vibration - works great and doesnt move but I think i should have a battery box in there. Just dont know what to buy or how to mount it. I also cut off the side brackets attached to the frame so i will probably have to tap the swing arm and or use the rear fender bolts(?)Also rigged the ignition switch but a need an elegant solution for that too. But all in all Im pleased. My wife however, thinks I've totally lost it.
ocman is offline   Reply With Quote
Old 04-14-2006   #2 (permalink)
Favorite Bike: 2005 Bonneville T-100
Panthermark's Avatar
Your wife is correct....you have lost it. But that started the minute you said "I do".
:knkknk:
Now show us some pics!!
:-D
Mark
Old 04-14-2006   #3 (permalink)
Other Motorcycle: 66 Bonnie Chop
Never pay any attention to females that call themselves "wives". They have their own agenda's and cannot be trusted in matters of motorcycles & cars. Sounds cool, probably a shop could make you up a custom box. Or get a gel battery and don't worry about it? (plus they are usually smaller)
Al
ssjones is offline   Reply With Quote
Old 04-14-2006   #4 (permalink)
She has better taste in men than in motorcycles :wink:
I dont know what a gel battery is. Wouldn't it still need to be mounted with a box or bracket?
Old 04-15-2006   #5 (permalink)
Check the Harley parts vendors [J&P cycles,vintage parts catalog]They would have small boxes for batteries,or try a bike wrecking yard.My old SL175 donor bike has a small battery cage [too small for Bonnie] that could be enlarged.Gel batteries work great,some even upsidedown,then painted black to blend in with the frame.A leather tool bag to match your seat with the battery inside,carve out a recess in your seat foam,get a magneto and bumpstart the bike every ride. :-D
rodburner is online now   Reply With Quote
Old 04-15-2006   #6 (permalink)
Hey rodburner,
Any problem with keeping my current set-up? I just laid the battery flat on the swingarm in front of the rear tire and wrapped a leather battery strap around it attached under the swingarm with a bolt and nut. It seems stable as ive riden over potholes and rr tracks and it doesnt shift at all. Obviously, i need to check the strap from time to time, but do see any problem with just leaving it this way? it looks pretty clean.
Old 04-15-2006   #7 (permalink)
You can put them in any position, not as easily damaged by vibration, etc.
Al
00/01 battery box question DEcosse Daytona Deliberations 1 04-13-2007 10:06 PM
Help identifying 00/01 Battery box part DEcosse Speed Triple Forum 4 04-13-2007 09:59 PM
Battery Box / NARK Mod ramblinfool Club Cafe 1 02-21-2007 05:33 PM
Very Hot Battery Box and Seat RatBoy The Rocket Science Forum 22 09-10-2006 09:01 PM
fuel leaking from upper battery box screws LgyoTiger900 Tiger Workshop 1 09-05-2005 04:40 PM
