Old 04-11-2006   #1 (permalink)
It finally happened yesterday. I simply forgot to put my kickstand down and by the time I realized it, I was past the point of no return and I had to slowly let the bike go down (while still holding it). Anyways, besides a dime sized scratch on the left pipe and a scratch on the housing where the shift lever hit it, all seemed fine. And then as I got on to drive home last night, something looked/felt a little funky, and after sitting on the bike for a couple minutes trying to figure out what it was, I realized that the cheap (metal?) housing that attaches to the forks and holds the headlight and shifted/bent to the right (if sitting on the bike). I grabbed it and realized that it easily shifts left and right a little bit, but one the brackets IS bent the slightest bit.....Anything to worry about or should I just forget about it....?
Tenover is offline   Reply With Quote
Old 04-11-2006   #2 (permalink)
Favorite Bike: 2005 Bonneville T-100
Panthermark's Avatar
Sorry to hear about that...
Those brackets are worthless....don't worry about it. You can try to tighten everything to the max, and you will still be able to move your headlight up, down, left, and right. My eyelid visor catches a lot of air and pushes the headlight up. I don't even bother to use the high beam at night....as I would basically be illuminating the moon.
:hammer:
Mark
Old 04-11-2006   #3 (permalink)
Actually, funny you should mention that. Not funny about your bike though, sorry. I had to let my down recently and the peg busted off.
Anyway, i was installing my fairing last night and realized that i could take the headlight and those brackets and move them side to side. Is that normal? I had removed my forks recently and want to make sure i put everthing back together right.
-dennis
2004 Triumph Thruxton
d2mini is offline   Reply With Quote
Old 04-11-2006   #4 (permalink)
Favorite Bike: 2008 Victory Kingpin
Silverado57's Avatar
Other Motorcycle: 2006 Victory Vegas
Extra Motorcycle: 2005 Speedmaster (Ret.)
This happened to me very early on and fortunately the only mishap was a slightly scratched mirror.
If nothing else I hope I learned a potentially hard lesson the easy way for a change.
Kevin
Luceo Non Uro
NJ USA
Silverado57 is offline   Reply With Quote
Old 04-11-2006   #5 (permalink)
Those brackets are not actually secured to anything, its normal for them to move around a little, I wouldn't worry about that.
My Baby
Copper is offline   Reply With Quote
Old 04-11-2006   #6 (permalink)
Favorite Bike: 2004 Bonneville America
Bryan's Avatar
Other Motorcycle: 1976 T140V {Bonneville}
Extra Motorcycle: 68'YCS1E,71'CT90,82'XL80
Coppers right. You might even try to bend it back a little if it's noticeable. Sometimes you can buff out scratches on chrome or aluminum and it looks just fine.
Bryan is offline   Reply With Quote
Old 04-11-2006   #7 (permalink)
Other Motorcycle: 66 Bonnie Chop
Not certain about the Bonnie, but the America/Speedy's need the rear brake bled when tipped over. Make sure no air entered your fluid reservoir.
Al
ssjones is offline   Reply With Quote
Dropped Bike Rainmaker Twins Technical Talk 15 06-21-2007 02:12 PM
I dropped my bike! TJRCARRILLO Club Cafe 4 05-27-2007 11:42 PM
bike stalled and dropped. DrTriumph Sprint Forum 11 07-22-2006 11:15 PM
Advice of dropped bike... AAA Sprint Forum 4 06-10-2006 07:41 PM
Almost dropped my bike!!!!!! RT Twins Talk 24 04-27-2006 06:13 AM
