Motorcycle.comBikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 04-08-2006   #1 (permalink)
Well, after reading many posts and racking up 3,000 miles, I have decided to get the Epco slash cut pipes for my 2005 SM. This will be my first engine modification and I do have a question or two...more to come I am sure:
1). If I replace the pipe will I have to do anything adjusting to my carb???? I think the answer is no because I am not affecting air intake into the carbs but could be wrong.
2). If I replace the pipe and remove the snorkel, will I have to do anything to my carb???? A firm maybe is where I am at on this because you are adjusting the air intake which might mean you have to do some adjusting. If so, is there any good links that point out where you adjust the carbs at??
I don't mind adjusting but want to hold off on replacing any needles(?) until I get the freak. I hope this statement makes sense because I forgot the technical terms.
thanks in advance.
Kevin...
PS: the wife should know about midweek that I purchased pipes. Does anyone have any room in their house for me? ;-)
schwartzkm is offline   Reply With Quote
Old 04-08-2006   #2 (permalink)
Other Motorcycle: 66 Bonnie Chop
I don't think you will have any problems, but with no carb adjustments, you won't be realizing the full performance potential of the pipes. I don't think there is any harm in waiting until you Freak the bike, which would definitely require rejetting.
Al
ssjones is offline   Reply With Quote
Old 04-09-2006   #3 (permalink)
They do come with 130 main jets for the 790 engine. Don't know about the 865. Changing the mains will make quite a difference in performance with these pipes
trashcanman is offline   Reply With Quote
Old 04-09-2006   #4 (permalink)
Need and want are two different things
Pack Leader, LINY RATs
'02 Black Bonnie America
Anyone on long island?
bennybmn is offline   Reply With Quote
Old 04-09-2006   #5 (permalink)
If I recall, the 2k5 SM comes with 130 mains.???
Slash cut stock pipes midlifespeedy Twins Technical Talk 6 06-16-2007 05:43 AM
Slash cut pipes for Speedmaster Bushrat Twins Technical Talk 24 03-12-2007 06:34 PM
Slash cut pipes speedmaster tc995i Twins Technical Talk 2 02-22-2007 06:03 AM
slash cut triumph short pipes for $350 vs the $650 TOMKRILL Twins Technical Talk 10 12-31-2006 04:20 PM
Long slash cut TOR's Brit26 Twins Technical Talk 1 07-24-2006 02:06 PM
