I can't speak for the Bonneville, but my W650 requires chain adjustment no more often than every 5000-6000 miles. I do lube chains every 400-500 miles.
The W650 has been ridden approximately 47000 miles, and I replaced the original chain and sprocket set at 18000 miles. The second chain and sprocket set was replaced at 38000 miles (DID XRing). I may be overdoing it, but when the sprocket teeth get worn and take on a curved profile, I follow the chain manufacturer's recommendation and change both the chain and sprockets.
I'm guessing I'll be changing chain and sprockets on the T100 at approximately the same mileage intervals.
Do these intervals (approx every 20000 miles) sound right to you guys?
Bob
