Old 04-03-2006   #1 (permalink)
Favorite Bike: '06 Scrambler
Other Motorcycle: '07 F650 GS
1) I am getting seepage out of both side covers on my new Scrambler. Is this something others have seen on their twins? If so, what is the fix? I am taking it to the dealer this week but a forewarning would be good.
2) I decided the bike needs the progressive springs in front which my dealer had a set in stock for a good price. I figure they are straightforward to install, any things I should watch out for?
Thanks,
Fred
No such thing as cold weather, just inappropriate clothing.
pigpen955 is offline   Reply With Quote
Old 04-03-2006   #2 (permalink)
I get seepage. It's from what I believe is right hand crankcase cover (the side cover on the right that's near the bottom of the bike right behind the rear brake pedal). I don't know if it's normal. I was planning on asking the same thing, or asking my mechanic when he installs a new oil pressure sender - also causing leakage but from a different place.
jsdc2005 is offline   Reply With Quote
Old 04-03-2006   #3 (permalink)
Favorite Bike: 2004 Bonneville America
Bryan's Avatar
Other Motorcycle: 1976 T140V {Bonneville}
Extra Motorcycle: 68'YCS1E,71'CT90,82'XL80
Is it the cover that looks like this.Click here to see the shape of the cover. :???:
Bryan is offline   Reply With Quote
Old 04-03-2006   #4 (permalink)
Yup, mine is! Even the trickle pattern looks the same
So I guess I have an "output shaft seal oil leak"? Sounds like fun. Not too expensive to fix I hope.
Old 04-03-2006   #5 (permalink)
pigpen!
I got seepage (weeping) from the primary (left side) and sprocket (right rear) covers in under 700 miles on my T100. I washed the bike at 700 miles on the clock and it has not resurfaced in the 150 miles since washing it. I'll keep a watch on it and keep you posted. It does not bother me too much because Elvis (My Harley) always weeps from the primary! Chalk it up to character of the bike! The only thing I can think of is perhaps the covers(T100) needs to be re-torqued after a few heat cycles. I'm sure the boys on this site will provide some good info!
DesertRunner
DesertRunner is offline   Reply With Quote
Old 04-03-2006   #6 (permalink)
Yeah, I have the same problem! Going to the dealer on Friday, still under warranty!
04BB
1409 is offline   Reply With Quote
Old 04-03-2006   #7 (permalink)
Other Motorcycle: 66 Bonnie Chop
$7 for the seal, but a SOB to install. Someone posted to install correctly, the case has to be broken open. I put one on my bike that left a few drops. Very aggravating install, you really have to find some type of drift. I buggered the soft rubber outer covering on my seal, it doesn't look pretty, but so far has been dry. Someone mentioned freezing the seal before installation. In hindsight I should tried that (also put some dielectric grease on the seal to lubricate on install).
Al
ssjones is offline   Reply With Quote
Old 04-03-2006   #8 (permalink)
LT
Favorite Bike: '05 America
LT's Avatar
Other Motorcycle: '93 BMW R100 RT
You're sure it isn't chain lube?
LT is offline   Reply With Quote
Old 04-03-2006   #9 (permalink)
Retired Legend
sweatmachine's Avatar
I have the same problem on my T100, I just noticed it last night. I thought it might be from the chain, but I rarely oil my chain. I'd be interested to know *** it is.
Old 04-03-2006   #10 (permalink)
NO! I cleaned the chain and the area under the cover, it is motor oil! It's hard to tell where the oil is coming from, if I put my hand under the gearchange mechanism cover (below the sprocket cover) I get oil all over my hand! :evil:
04BB
New here,,Have some questions for you! TR6SSDU1834 Classic, Vintage & Veteran 10 04-02-2007 09:39 AM
Daytona 675 Questions & Inline 3 Questions TeddaGreek Daytona675 Forum 11 12-27-2006 11:18 PM
06 s3 questions vendman T3 Sport / Touring Forum 3 09-02-2006 11:44 PM
Two questions please... IrishJohnny Club Cafe 7 09-29-2005 08:18 PM
Saying hello and a few questions rags Speed Triple Forum 2 06-07-2004 05:58 PM
