BikeBanditAdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
Old 04-02-2006   #1 (permalink)
im having a hard time wiring up this thing. i can get the brake light to work but not the running light? can anybody who has done this mod help me out please.
lucas light 1red,1black
factory 1 blue,1red,1black.
what goes where?? im also new to the forum so thanks for all the help when i was deciding future mods to do....thanks guys.
blue-thrux is offline   Reply With Quote
Old 04-02-2006   #2 (permalink)
blue...I believe the Lucas light fixture needs to grounded to the chassis and the black/red leads are for the running/brake lights...Not sure which is which. Hook them up, you've got a 50/50 shot at getting it right. Just reverse them if they're backwards...
SCbonneville is offline   Reply With Quote
Old 04-02-2006   #3 (permalink)
BlueThrux, the blue wire is the brake light,red is tailight,black is ground.Run the bikes black wire to one of the mounting screws that mount the light to the fender,then touch the blue bike wire to the lights wires one at a time to see which is the brighter light. the other lucas wire will be the tailight.Make sure you try it with the key on and the front brake lever pulled back and taped to the grip so the brake light will work.
Old 04-02-2006   #4 (permalink)
rodburner, i just cant get the running light to stay on? ican get the brake light to work (the bright filament) but the running light (not so bright filament) will not stay on after brake is let go??? am i stupid what in the world is going on? thanks for the help.
Old 04-02-2006   #5 (permalink)
Desperado
Hi blue-thrux. I installed a complete 68 BSA tail light on my 01 bonnie. A third (ground) wire must be added to the lucus unit and then attached to the gound in the thrux wiring harness. The rear fender on the new bonnie is not grounded. good luck. desperado
Old 04-02-2006   #6 (permalink)
Blue,if the black bike wire is screwed to the light body[or mounting bolt] and the blue bike wire is hooked to the red[?] Lucas wire,the brake light should work when you pull the lever [key on]. The red bike wire should now be hooked to the black Lucas wire.The tailight should now be on also.It should stay on [key on] when the brake is released. If it doesn`t,try switching the red/black Lucas wires to the bikes blue/red wires.I can`t remember which Lucas wire was which element,but you only have 2 choices.
Old 04-02-2006   #7 (permalink)
i think my ground is good but where do i hook the new wire to the lucs light desperado??
Old 04-02-2006   #8 (permalink)
rodburner this thing is driving me crazy. when iswitch the blue and red wires all it does is switch elemnts? never leaving me with a running light. there isnt a seperate fuse for that is there? thanks
Old 04-02-2006   #9 (permalink)
Favorite Bike: 2004 Bonneville America
Bryan's Avatar
Other Motorcycle: 1976 T140V {Bonneville}
Extra Motorcycle: 68'YCS1E,71'CT90,82'XL80
blue-thrux: Yes according to the Bonneville wiring diagram there is a separate fuse for the running lights. I'm not really sure about your Thruxton but the diagram says it's fuse # 10. I hope this helps you.
Bryan is offline   Reply With Quote
Old 04-02-2006   #10 (permalink)
Desperado
hi again from desperado. sounds like your just having a great time. I think I sauldered a wire right to the light bulb housing. My bike's in a unlit garage but I'll look at it tomorrow and tell you exactly what I did and what wires went where!
Lucas Tail Light Wiring rbrian_taylor Club Cafe 9 09-23-2007 01:45 PM
Lucas tail light wiring rbrian_taylor Twins Technical Talk 3 09-11-2007 05:23 PM
Lucas Rear Light bigred900 Hinckley Classic Triples 11 05-15-2007 05:14 PM
lucas tail light Freeze Club Cafe 0 07-20-2006 12:47 PM
Lucas taillight wiring help Tbear Twins Talk 7 09-14-2005 03:53 PM
