I have asked Bellacorse about parts interchangeability....this is what they have to say so far:
Most chassis parts crossover such as shocks, fork springs, tail lights, chains, sprockets, seats, brake parts, fuel caps and mirrors. The handlebars, headlight and high exhaust are the only areas where Bonneville parts will not crossover.
1. Would anything that works on the Speedmaster engine work on the Scrambler? Yes with the exception of the OE style air filter, there you would use a Bonneville version.
2. Are the Bonneville and Speedmaster engine cases (outside covers) interchangeable? I'm thinking of putting the black case covers on a Scrambler..if price isn't too outrageous. Yes, they are interchangeable.
3. Do you sell the OEM Accessories such as the Single Scrambler seat with rack? if so, how much? availability? Same for the performance silencers? Sorry, no. Just aftermarket parts.
4. Does the basic rejetting kit work for all Bonnies or do I need specifically a Speedmaster/Scrambler one. Same "types" of jets, however different sizes.
5. any other engine guards (dresser bars) then OEM accessory that would work on a Scrambler? Not to my knowledge.
6. is the airbox elimination kit different for the scrambler? your webpage said to ask about it.... As far I can tell from photos, the ABEK will fit the Scrambler, however there is an issue about the fuse block fitting in a convenient location. With the high pipes, the fuses on a Scrambler is located a couple of inches higher.
The Big Boo and Boo
(Gary and Michelle)
