Old 03-20-2006   #1 (permalink)
I was noticing when cruising along in 4th gear with the rpms up at about 5k, the tach needle is bouncing around between about 4800 and 5100 rpms. Throttle is steady and the bike seems to be running smooth, no jerkiness or anything that I can feel. But the needle is jumping around. And the needle seems fine the rest of the time, just around that 5k area.
Is this normal? :???:
-dennis
2004 Triumph Thruxton
d2mini is offline   Reply With Quote
Old 03-20-2006   #2 (permalink)
Mine does it around 4,500 ... although since I synched the carbs, it doesn't seem to have as big a bounce.
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 03-20-2006   #3 (permalink)
HiVel's Avatar
Yes, it seems a regular thing to be on certain bikes-why? Who knows? My 05 T100 did it and I had the dealer replace the igniter box under warranty- it still does it! Just ride and enjoy . Seems to be a harmless happening.
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 03-20-2006   #4 (permalink)
Ok, good. As long as nothing is about to explode. :-D
-dennis
Old 03-20-2006   #5 (permalink)
Yeah, it's real steady though if you go through 5K so fast it can't bounce back and forth. :-D I sometimes use that as an excuse to cruise at 5500 rpm instead of 5000 rpm. The standard bonnie guys are probably saying to themselves--Why don't these guys get a life. :-D
Larry
Larry
Old 03-21-2006   #6 (permalink)
Favorite Bike: Whatever I'm riding
Do you really cruise at 5K in 4th gear? Change up to fifth and increase you mileage!! :-D
Nang
2004 Thruxton
Nang is offline   Reply With Quote
Old 03-21-2006   #7 (permalink)
My thrux does the same thing around 5k.
If I agree with you, we would both be wrong!! Vinny
azvinny1971 is offline   Reply With Quote
Old 03-21-2006   #8 (permalink)
When i'm in the twisties. I like to keep it in a lower gear so i can use engine braking before the turn, then have plenty of power to accelerate through and out.
[ This message was edited by: d2mini on 2006-03-21 07:04 ]
-dennis
tach needle shake? FuryFour Triumph SuperSports 28 05-20-2008 11:26 AM
Left needle vs. right needle? TCL Twins Technical Talk 5 03-18-2007 04:24 PM
What usually causes Speedo. and Tach. needle bouncing? Milkbone Classic, Vintage & Veteran 8 10-15-2005 07:37 AM
Bouncy Tach Needle - Carb Sync??? jasmail Hinckley Classic Triples 20 12-08-2004 09:31 PM
Tach needle jumping erraticly Greaser Hinckley Classic Triples 10 08-30-2004 05:51 PM
