Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
BikeBandit
Old 03-17-2006   #1 (permalink)
RobbieKnobbie
Has anyone seen the torque/HP curves for the various Bonneville twin motors? I'm considering the T100 and the Scrambler but I need to know how the actual output compares - not just peak numbers.
Thanks!
Old 03-17-2006   #2 (permalink)
When I had my '03 Speedmaster dyno'd, my peak torque was about 46.5 Ft-lbs at about 5 grand. I had a nasty spike where the a/f went ultra lean at around 3500, due to bad jetting on my part, but besides that, torque stayed between 40 and the peak for the entire range. When I dyno'd, the guy figured that I was probably running about a 17:1 A/F ratio, which is way lean; now that I've rejetted, and done a few ignition mods complements of Brent, I'd expect to be around the 48 to 50 Ft-lb range.
Michael D. Rodriguez
RoundSlide is offline   Reply With Quote
Old 03-17-2006   #3 (permalink)
Thomson
Also the 904cc torque curve would be very, very interesting...
790 vs 865 Torque Curves Motorboy Twins Technical Talk 6 03-25-2007 07:53 PM
Curves and Twisties d8ug The Rocket Science Forum 14 06-12-2006 11:51 AM
more dyno curves thruxtonone Twins Talk 1 06-17-2005 03:20 AM
Thruxtonone dyno curves thruxtonone Club Cafe 10 05-11-2005 12:01 AM
curves in the cornbelt tomhorn Speed Triple Forum 7 05-13-2004 02:27 PM
