Actually, once you've done it a couple of times, removing the tank is very easy. Always remember to plan for a place to put the tank BEFORE you have it in your hands. :-D Don't ask me how I know this, please. A small cardboard box that is deep enough for the petcock to clear is my first choice--I sit the tank across the box with the petcock just touching one side. It also helps to plan ahead and not have much gas in the tank. You should be able to remove and replace the vent hose by feel without looking at it after a couple of removal/replaces. :-D
Larry
Larry
