I wanted to do that but cutting them would mean cutting off the threaded part that allows them to attach to the housing and blinker shell. I saw no way of doing it short of fabricating something. So i bought new blinkers, which was good because i also hated the stock speedmaster ones. I'm not sure exactly how the bonnie ones differ, but if they also have threaded ends you'll have the same problem. Look at the pic of my bike in my signature and you can see the ones i installed which only stick out a couple inches in the rear. Of course the front on the speedmaster aren't on stems so it's only the rear that i had the problem with. But i got them all around to match and because they look so much better than stock.
