I took off the carbs, found the main jets and pilot jets to be not plugged. No nasty gas smell, or smeg. Put in new plugs, put in allen screws in carb, checked the diaphram, no apparent holes. Air hole not plugged in slide. Not sure how to clean the starter jets, but running a piece of safety wire up in there didn't allow it to go very far on either side.
Adjusted the idle screws to 2 3/4 turns, per instructions.
Ran vacuum balance hoses between both the carbs and the intake manifolds vacuum ports.
removed/ inspected air filter, no obstructions, no vacuum leaks.
Bike still runs on one cyl (l/h) with choke out, then after a little while, it picks up the r/h cyl intermittently. Runs like stink when it "catches"
Plug wire ends going into coil are shiney, not corroded. I did NOT run a resistance test on them yet.
Lh plug chocolate brown rh was black, not tooo sooty.
Any ideas? The bike runs better with choke out, but still intermittent. Spooky....
shorty
[img][/img]
