Turn signal self cancle - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-06-2006, 12:32 PM   #1 (permalink)
Well I did it sold The Harley bought 06 T100 only 250 miles so far but haven't looked back. My problem after riding Harley's for the last # of years I can't remember to turn the signal off. What is the best self cancel unit ? Badlands has one that needs to be wired in and has a load equalizer for L.E.D. Kriss has one that needs to be wired in that doesn't have the eq. New Bonn. has one that is plug and play but doesn't have the eq either. Whats best ? Oh buy the way on the Bonnie A/I removed BUB pipes jetted and uni filter before I picked it up. Last English bike I bought new was a 63 BSA Lightning Rocket. I figured you folks with your wealth of knowledge would have the answer.
Thanks
If God had not wanted us to eat animals why did he make them out of meat.
tankspop is offline   Reply With Quote
Old 03-06-2006, 01:27 PM   #2 (permalink)
I've got the one brent carries. Theres one problem with those that drives me nuts, but to be fair i'm not sure ANY brand can get around this problem.
When you forget to turn them off they go off by themselves as they are supposed to, but the problem is that next time you go to turn them on you have to first turn the button off. The other problem thats worse even is that sometimes even when the button HAS been turned to the off position, the signals don't go on when you try. I believe this happens if you turn them on for too short a time before turning them off. (maybe one blink) But i'm really not sure exactly if thats why. I tested it when i first got it and found what makes it do this but i can't recall exactly. But suffice it to say it's a pain. Is it worth the pain? Yes...it may be a hassle but it's better than hitting a car that just turned left in front of you !
And as i said b4, i'm not sure anyone can build one that eliviates both problems because the button is mechanical, so theres no way to electronically set it back. The other problem i'm not sure tho.
Old 03-06-2006, 02:26 PM   #3 (permalink)
Favourite Bike: All of them.
Shakey's Avatar
Other Motorcycle: Moto Guzzi California EV
I've never owned a bike with self cancelling signals so it's not an issue. Like hitting the brakes, or shifting gears it is just second nature. Do I forget on occasion? Sure thing, but not often enough to warrant an aftermarket solution that works, sort of. I even use hand signals to change lanes, or turn. That's a true self cancelling system. :-D
Ride safe and often.
Shakey is offline   Reply With Quote
Old 03-06-2006, 05:50 PM   #4 (permalink)
Favourite Bike: 2009 Victory Vision
Silverado57's Avatar
Other Motorcycle: 2008 Victory Vision
I had considered the self-canceller at first. After some more riding, cancelling it manually became more "automatic" when I'm reaching for the clutch to upshift after going through the turn.
Kevin
Luceo Non Uro
NJ USA
Silverado57 is offline   Reply With Quote
Old 03-06-2006, 07:27 PM   #5 (permalink)
Favourite Bike: '68 BSA Lightning 650
WaltZ's Avatar
Other Motorcycle: '78 Honda CB400a
Extra Motorcycle: Sportster 1200c
Eh - try this one; '06 J&P Cycles catalog PG 174, #320-269 Kisan signalMinder for Triumph - Bonneville. $99.99.
Built-in programmable time-outs 15, 30, & 45 seconds. Allows u to convert all turn signals to running lights as well.
http://www.jpcycles.com #320-269 Kisan signalMinder
Let me know if it works as advertised, especially as turn signal running lights. :-D
- Packy, the
'04 B&W T100
The Bike I Ride
WaltZ is offline   Reply With Quote
Old 03-06-2006, 08:48 PM   #6 (permalink)
thats the same one i have as i mentioned above that i got from brent.
Old 03-06-2006, 09:20 PM   #7 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
I have the Kisan unit from Newbonneville. It works fine for me. It cannot reset the Triumph manual signal switch; however, it cancels the turn signal 100% of the time. Someone said they can remember to turn off the signal most of the time--it only takes one time to kill you! I live in a state where only 5% or less of the drivers (including local and state policemen) use the turn signal. One can be sure that if they signal most drivers will know they mean to turn.
I simply hit the reset button prior to signalling--it works 100% of the time, also. I believe the problem Daz mentioned has to do with the Triumph turn signal switch--you turn it on by moving the switch, but always turn it off using the reset button, otherwise sometimes it won't turn on for you--this was the case for me PRIOR to buying the signal cancelling unit.
Larry
Larry
Old 03-06-2006, 09:39 PM   #8 (permalink)
Thanks for the input.
Old 03-06-2006, 10:35 PM   #9 (permalink)
Mine does too, thats not what i was saying.
Thats how i do it.....i hit the button. But still sometimes it doesn't start the next time i switch it on and i have to hit the button a second time and turn it on again. I honestly think this thing is flawed big time, but as i said it's worth the trouble to stay alive. Someone else cited the same problem a while back.
Turn Signal Daytona Deliberations 4 10-11-2010 02:35 PM
turn signal bulb johnO Sprint Forum 0 05-28-2007 01:29 PM
Right turn signal out raff Twins Technical Talk 10 05-25-2007 10:33 AM
turn signal? Jacksmack77 Twins Technical Talk 1 04-13-2007 03:23 PM
Turn signal buzzer TucsonBill Tiger Workshop (archive) 13 05-19-2006 03:29 PM
