Scrambler Mods - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-05-2006, 09:19 PM   #1 (permalink)
Removed the AI today and plunked in a K&N Filter.
Seemed to be a little hesitant when blipping the throttle.
Any suggestion to how many turns out I should go in the idle mixture.It was 1 1/4 and I backed it out another 3/4 turn and it has improved a bit.
Sprocky is offline   Reply With Quote
Old 03-05-2006, 09:57 PM   #2 (permalink)
Favourite Bike: 04 Bonnie black
I set mine at 3-1/4 turns out when I did the AI. I have not touched it since.
Old 03-06-2006, 08:51 AM   #3 (permalink)
You have the 865cc/270d engine, same as the Speedmaster. You should reseach what SM had done to their bikes in terms of jetting.
Countershaft sprocket changes are dirt cheap and aggressive brake pads are always a good idea.
<html>
<body>
<p align=centre>
<A href="http://www.bellacorse.com/index.html"
http://www.bellacorse.com/images/bclogo.jpg</A>
</body>
</html>
RaceDweeb is offline   Reply With Quote
Need Advice-Scrambler Mods! rmak Twins Talk 6 12-07-2007 05:26 PM
Scrambler tacho mods ???????? sprocket42 Twins Technical Talk 0 09-29-2007 07:16 AM
Scrambler mods continue tri650 Twins Technical Talk 5 01-27-2007 06:39 AM
Scrambler Mods Sprocky Twins Talk 13 06-05-2006 10:32 PM
