Brittwin,
The jets are located under the float bowls which are on the very bottom each carb. The float bowls are held in place by four phillips head screws (each bowl) and with patience and a right angle screwdriver can be removed on the bike. Once you get the float bowls off take care not to bend anything related to the actual float, The float will be the dangly thing. The float meters fuel into the carb and works like a toilet valve. To remove the float you pull the pin at the float pivot, be careful to note where the peices go, there will be a little spring and the float needle that will also come off when you pull the pin. The jets are made of brass and are about in the center of the carb. The main jet will be screwed into another brass peice (needle jet). Hold that brass peice in place with an 8mm wrench and use a rt angle straight blade screwdriver to remove the jet. Normal right hand thread and try not to let the screwdriver hop out of the slot while torqueing cause that brass is soft. When reinstalling the float bowl get a set of allen head carb screws from New Bonneville and use them instead of the phillip head screws. Just makes it easier.
The needles have to be changed from the top of the carb, I have not changed mine but it looks like this can be done while the carbs are on the bike as well. Remove the cover over the top of the carb (4 phillips heads and you will get new allen heads with the kit from New Bonneville) and under the cap you will see a black plasticy looking thing, pull out the spring and then the black plastic diaphram and slide. The needle will be stiicking out the bottom of the slide, remove the retainer inside the slide and replace the needle. Put everything together like it came apart being very careful with how the plack plasticy diaphram goes. If that does not seat properly or gets a small hole in it you will be unhappy. Easy enough to do though so don't fret it.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
