pweitz,
I recommend you put your bike info in your "sign-on" or what ever it's called so it shows up under your name. This way we know what year and model you have and can answer your questions with more/less confusion. :-D
If your bike is a 2004 or later, you will need a "D" tool in order to adjust the pilot screw (also referred to as the "air/fuel mixture" screw).
Larry
Larry
