T100 vs. Thruxton - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-03-2006, 01:40 PM   #1 (permalink)
I'm just wondering how the Thruxton generates more horsepower than the T100. The specs look identical. Anybody know?
Mezambo is offline   Reply With Quote
Old 03-03-2006, 01:53 PM   #2 (permalink)
Favourite Bike: 2005 Bonneville T100 (B&W) - Chromed like a Harley
raproe's Avatar
Ask the Triumph marketing department. I doubt that their engineering department can figure it out either.
"....by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself."
raproe is offline   Reply With Quote
Old 03-03-2006, 01:56 PM   #3 (permalink)
Favourite Bike: 2005 Bonneville T-100
Panthermark's Avatar
That question has been around for a long time.
My guess is that the stock Thrux pipes (and maybe the kink-less header pipes) has a lot to do with it....
Mark
Old 03-03-2006, 02:50 PM   #4 (permalink)
G'day,
Maybe it's the tapered needles. :razz:
Missing OZ
My Pics
iandel is offline   Reply With Quote
Old 03-03-2006, 03:37 PM   #5 (permalink)
Favourite Bike: 96 TBird
Other Motorcycle: The Wife's T100
A 'Standard' T100 may have less HP than the Trux. Better pipes, rejetting etc and they are probably comparable.
It's a nice day for a ride....
Moggy is offline   Reply With Quote
Old 03-03-2006, 03:38 PM   #6 (permalink)
Favourite Bike: 2003 T100
ohiorider's Avatar
The info we don't see (I don't see, anyway) are the specs that show:
- differences in carb setup, if any
- ignition timing advance curves
- cam timing and overlap
- any diff in airbox
- any diff in intake runner length/shape
- probably a bunch more
New BMW twins spec out basically the same re bore and stroke, but subtle design differences allow them to build flat twins that range from 100hp (R1200 GS) to 122 hp (R1200S) with other models rated at approximately 110 hp. This is all measured at the crankshaft, not the rear wheel.
I think I'd find the same thing if I pulled up the specs for Triumph's various models using the 955cc triple. Bore and stroke would be the same across all models, but hp would vary considerably between the Tiger, Speed Triple, and the Daytona 955.
Old 03-03-2006, 04:55 PM   #7 (permalink)
raproe's Avatar
On 2006-03-03 12:50, iandel wrote:
G'day,
Nope, they both have the same NBZT needles. All the carb specs are absolutely identical. Valve timing and overlap are also absolutely identical.
[ This message was edited by: raproe on 2006-03-03 14:59 ]
Old 03-03-2006, 05:10 PM   #8 (permalink)
Having ridden side by side.. my Thrux and a T100 I met along the road, I don't think there is any difference (in a straight line..) Although I did leave 'em when the road got twisty...but I don' t think that had much to do with the bike, just me knowing that particular stretch of road REAL well
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 03-03-2006, 05:20 PM   #9 (permalink)
I'm with raproe on this one. The difference in output between these two bikes is, in all likelyhood, nothing. Then again, Triumph like to play fast and loose with specifications, so anything that they publish should be taken in with some degree of skepticism.
Psyched Out and Furious
WANG is offline   Reply With Quote
Old 03-03-2006, 05:39 PM   #10 (permalink)
More horsepower means little..... look at the differences in how/where the torque is delivered. Maybe not to the naked eye, but the T100 may actually be quicker from stop-light to stop-light.... i.e. 'torque'.
What differences CAN be seen would be to include the positioning & length of the carb's intake, the length/distance of the header to it's first bend, and the cans. Hasn't it been suggested that the cam's are different too?
But the differences between the T100 & Thruxton are not limited to the engine, consider where else one's money is going when springing for the Thruxton......
- 'Rider' -
Click here for a view of my Member's Album.
FattRat is offline   Reply With Quote
Thruxton needles-T100 - my***** up mkchev Twins Talk 1 05-31-2006 03:18 AM
T100 jetting & differences between T100 & Thruxton engines. Nourton Twins Talk 4 05-17-2006 05:48 AM
T100 or Thruxton ? OldSwede Twins Talk 20 10-22-2005 10:06 PM
Thruxton Wheels & T100 VR6 Club Cafe' 1 08-14-2005 12:30 AM
Thruxton Wheels & T100 VR6 Club Cafe' 0 08-13-2005 11:59 PM
