Old 02-11-2006   #1 (permalink)
mecscc's Avatar
Took my new BBlack for a spin around town today to work some Stabil into the carbs. Too cold to go far (27f)
Anyway, Can someone point me in the direction of any thread that discussed alternative mirrors for a stock hinckley Bonnie? I'm sure it is likely to have been talked to death on this forum but my search skills have struck out.
3/4 of my mirrors yield nice views of my elbows and arms. This is especially bad with a heavy winter jacket, but even with a light summer jacket I don't see how it would improve much. Longer, possibly bent, shafts would seem to get the mirrors out far enough so that I wouldn't spend alll the time admiring my elbows (not my best feature anyway.)
Advice?
Thanks,
Monte
BTW: the left shaft and the chromed nut at the end of it has some chipped chrome and a lot of rusting. I'd say the cosmoline didn't quite cover it. I'm sure the dealer will replace it, but that will only make me feel I didn't get the shaft -- it won't solve the smiling elbow problem :-D
Monte
"The Old Ohio Preacher Man"
Old 02-11-2006   #2 (permalink)
Jack lilley has mirror extensions. look at the online catalogue under bonneville then under frame accessories.
http://www.jacklilley.com
Other folks here have said that the yamaha cruiser mirrors fit but I have never tried them.
PCRider
"Be who you are and say what you feel, because those who matter don't mind, and those who mind don't matter." ~~~~~ Dr. Seuss
PCRider is offline   Reply With Quote
Old 02-11-2006   #3 (permalink)
I had the same problem with the aftermarket ones i installed. Added a spacer about an inch long to them to raise them up and that did the trick. Even tho they didn't stick OUT further, bringing them up helps because if you look at your arms as you're holding on to the bars, the higher up on your arms the further inwards they are because the grips are wider than your shoulders. That one inch made a world of difference for me. I don't know how you could achieve this with those perticular mirrors but if you can it'll help. Another option some use is to get bar end mirrors if you don't mind the look.
Old 02-11-2006   #4 (permalink)
Favorite Bike: 2005 Thruxton - 2001 Bonneville - 1995 T-bird
Other Motorcycle: 2003 BMW 650CS
Extra Motorcycle: 2007 XL1200N
I just received a set of mirror extensions for my Thruxton from Jack Lilley. Work great and good workmanship. I thought $50 to be a little expensive, but how do you put a price cap on your bike...
Larry is offline   Reply With Quote
Old 02-11-2006   #5 (permalink)
I have a set of mirrors from a Yamaha Vstar 650 on mine, they thread right ontothe end of the stock stalks. My understanding is that all the Star series mirrors wil fit, and can be had fairly cheap on Ebay.......They are oval or rectangular, so they have a better field of view than the round Triumph ones.
My Baby
Copper is offline   Reply With Quote
Old 02-11-2006   #6 (permalink)
Favorite Bike: Bonneville America 04
I KNEW you wouldn't wait!!!!!
Best,
Mare
Trumpet Cottage
In the foothills of the Blue Ridge Mtns
MA0458 is offline   Reply With Quote
Old 02-11-2006   #7 (permalink)
Just gonna look at her sittin in the garage, huh? Welcome back aboard a bonnie! Don't hesitate to ask--don't matter how much we have beat the subject to death--we'll gladly point you in a direction of the BIG $$$. :-D
Larry
Larry
Old 02-12-2006   #8 (permalink)
Location: Toowoomba Queensland Australia (gods country)
Bar ends are another option, providing your bars can accomodate them
Ozbon's album
old enough to know better...young enough not to care.
ozbon is offline   Reply With Quote
Old 02-12-2006   #9 (permalink)
mecscc's Avatar
Mare & RB: Well, I DID stare at it in the garage for a while, but then I realized that the gas the dealer put in was not stabilized, so I took a can and put Stabil in it and went and filled it, and brought it home, and put it in, and THEN I realized it wasn't in the carbs, and the streets were dry, even if it was below freezing, and well, what else COULD I do but ride it for 20 minutesllllllllllllllllllllllllllllllll :-D :-D :-D
Thanks for the advice on the mirrors everybody. I looked at the Lilly extenders but I'm so cheap I don't think I can force myself to spring for them (yet).
Anybody know if they are standard threaded 10mm stems on it, and if universal mirrors will fit? Universal mirrors fit most bikes.
I doubt if I would like bar-end mirrors, but appreciate knowing about that option.
Thanks much for the advice, folks.
Monte
Monte
Sprint RS Mirror extender/longer mirror Isa Sprint Forum 10 02-25-2007 08:41 PM
Valve Stems Bluetiger901 Modifications & Workshop Talk 6 12-18-2006 09:02 PM
Another mirror thread - ABM Billet mirror questions JontyG Speed Triple Forum 8 11-27-2006 02:28 AM
Shortening Stock Directional Stems NoPoz Club Cafe 1 10-12-2006 06:50 PM
MIRROR EXTENDERS FOR 05 BONNEVILLE SMOKNJOE Modifications & Workshop Talk 5 09-05-2006 02:23 PM
