Old 02-10-2006   #1 (permalink)
Has anyone used Mobile 1 15/50 synthetic when changing the oil---happy with the results? Thanks
kickenash is offline   Reply With Quote
Old 02-10-2006   #2 (permalink)
I use the mobil 1 V twin which is 20/50 i think. in any case i think it's good stuff after a lot of research. It meets all triumph's requirments and i think it's probably the same oil as the triumph branded mobil 1 product, and you can find it at most auto chains. Kind of expensive at about 7 bucks, but what the heck.....unless you ride a heck of a lot it's not bad. The general consensus is that you shouldn't use a lot of the auto oils because many have extended milage additives that are said to cause clutch slippage in wet clutches.
Old 02-10-2006   #3 (permalink)
Ahhh Grasshopper.... Learn to use the power of the search engine and heed my advise:
"Don't FIX it, if it ISN't Broken...!"
Mobil Motorcycle Oils
Seek not the advise of mere mortals.... the EXPERTS await your beckoning.
--Clark
Redmaster is offline   Reply With Quote
Old 02-10-2006   #4 (permalink)
where do you ususally buy your motor oil and how many quarts does a standard bonne take
trav13 is offline   Reply With Quote
Old 02-10-2006   #5 (permalink)
4 quarts of Motul 5100 avail. at my local bike shop, also if i give them a day they can get me the K&N-191 filter too.
fuzzdevil is offline   Reply With Quote
Old 02-10-2006   #6 (permalink)
Other Motorcycle: 66 Bonnie Chop
I use the Mobil 1 V-Twin Oil 20w-50, available from my local Autozone. NAPA Gold oil filter, #1358. The PureOne filter is also good, I just found they are available at Advance Auto. (#PL14612)
Al
ssjones is offline   Reply With Quote
Old 02-10-2006   #7 (permalink)
Oh, goody, an oil thread...I new one couldn't be far away after reading through that spark plug thread. :-D :-D
Larry
Larry
Old 02-10-2006   #8 (permalink)
Thanks for the Mobil link Redmaster, It is a quick read and informative. Good info.
I can throw an oil company farther than I can trust one on many issues but I think I will stick to the Motorcycle oil for now.
It does hurt the sensibilities to pay that much a quart.
PCRider
"Be who you are and say what you feel, because those who matter don't mind, and those who mind don't matter." ~~~~~ Dr. Seuss
PCRider is offline   Reply With Quote
Old 02-11-2006   #9 (permalink)
The 5100 is good oil BUt it is only rated SG not SH.
Darcy
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 02-11-2006   #10 (permalink)
cat
Favorite Bike: 70 tri bonneville
Other Motorcycle: xs 650
Extra Motorcycle: bsa 650 lightning
this winter i use rotella t synthetic 5/40 and the supertech filter walmart has. total oil change about 15 bucks. but...
come spring, back to mobil v twin syn and pure one filter.
engine is quieter with mobil 1 v twin. cheapest place i found mobil 1 v twin is at walmart, about $7.43 or so.
cat
cat
George: Oh, oh I've got a helmet! I got a beauty!
cat is offline   Reply With Quote
Oil Leak after Oil Change Teknic Speed Triple Forum 4 05-03-2006 01:35 AM
oil qty for oil & filter change??? cheapbastard Speed Triple Forum 8 03-29-2006 09:56 AM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 08:43 AM
First oil change, gear change still clunky M2MG Speed Triple Forum 3 09-03-2004 12:30 PM
how much oil is safe after oil change with filter shedds Hinckley Classic Triples 0 04-18-2004 07:39 PM
