In my research a 17" x 3.5" front and and 17" x 4.25" rear makes sense and provides a good choice of rubber. I also note some others have had lots of success with this wheel combination in Carrozzeria (not available anymore). I am leaning towards Kineo wheels for my 2004 Thruxton to reduce wheel weight although there are some issues such as speedo calibration and fitting a lower front mudguard with a 17 in front and offset with a fat rear. For these reasons I am likely to stick with OEM sizes as I like the nimble handling of the thinner wheels. If I stay 'thin' in Kineo then I am limited to Speed Demons, GT501 and perhaps BT45's in the OEM size
2004 Thrux, FCR39's, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin Gunfighter, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, dropped forks
