Any heat problems with xenon blue headlamps? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-19-2006, 10:21 PM   #1 (permalink)
I just ordered a xenon blue headlamp and was told by a buddy of mine that they have been known to melt the wire harness because they burn so hot.
Has anyone used these for any length of time and have you seen any problems?
Thanx
Dave
If you choose not to decide, you still have made a choice.
stdbkrhwk is offline   Reply With Quote
Old 01-19-2006, 11:10 PM   #2 (permalink)
Also would like to know. I put the xenon in a few months back haven't had problems yet. Hopefully someone has the answer.
PITTSBURGHRIDER is offline   Reply With Quote
Old 01-19-2006, 11:14 PM   #3 (permalink)
I had them on my last bike (Honda VTX 1800R) for over two years with no problems at all, they are brighter and whiter.
Bob_N is offline   Reply With Quote
Old 01-19-2006, 11:26 PM   #4 (permalink)
I put one in over 2 years ago and within a week it melted the socket. Others haven't had this problem. I guess you roll the dice and take your chances.
Union Jack tank and fender, silver bullet turn signals, Deuce risers, plus more. Click here for pic.
SalMaglie is offline   Reply With Quote
Old 01-19-2006, 11:32 PM   #5 (permalink)
I put one in about 6 months ago and have had no problems related to heat. My problem with the headlight is that he high beam is worthless. Believe it is the lens. I try to avoid riding at night but when I do ride in the country the high beam is worthless. I think I am going to switch in the spring to a 7 inch sealed beam halogen 6024. I read that these work well.
You've never rode until you've been throwed.
Anchorbend is offline   Reply With Quote
Old 01-20-2006, 01:01 AM   #6 (permalink)
I would wager that the reason some have problems and some don't is because of differences in the sockets. Some may be made out of a plastic that melts easier than others. Even on the same model they will source small parts like that from whoever has the best price at the moment, especially parts like that which aren't seen and don't change anything visually or performance wise. And you gotta realize that they probably don't consider the melting point because they aren't intending you to replace the light with a hotter type.
If you really want this and need to be sure you don't have this problem, just go buy new sockets that are made from a more heat proof material and some teflon coated wire and splice and solder yourself silly. It should be simple and then you'll certainly have no problems.
[ This message was edited by: dazco on 2006-01-19 23:05 ]
Old 01-20-2006, 01:08 AM   #7 (permalink)
mmelgar
I ordered mine through new bonneville 2 months ago, and no problems yet, just a brighter beam.
Old 01-20-2006, 01:44 AM   #8 (permalink)
Same here. I ordered them last month and have had no problems.
I have to disagree with Anchorbend. I think the high beams work great.
IMHO
bcohen is offline   Reply With Quote
Old 01-20-2006, 06:18 AM   #9 (permalink)
I used one a few years back in a different bike, it started to melt, had to replace the socket, but my friend has one in his Bonneville w/ no problems yet
TonUpMike is offline   Reply With Quote
Old 01-20-2006, 06:25 AM   #10 (permalink)
Favourite Bike: 1968 Triumph Trophy TR6R
Other Motorcycle: 2012 Tiger 800XC
Extra Motorcycle: 2003 Bonneville T100
SWMBO has one in her T100. No problems with heat and she runs her high beam in the day time.
Anchorbend, I think the problem is the reflector rather than the lens.
Carl S
Old Soldier
CarlS is offline   Reply With Quote
Problems dealing with heat from machine? TRISPEED Sprint Forum 72 06-04-2008 09:23 PM
LED headlamps! hardkore Speed Triple Forum 4 01-26-2008 11:27 AM
Trophy headlamps bobh RAT - United Kingdom 1 11-16-2006 04:39 PM
Aftermarket headlamps Goffe Speed Triple Forum 36 08-18-2006 03:11 PM
Xenon Headlights Sport Sprint Forum 48 03-01-2004 04:45 PM
