New Battery - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-12-2013, 03:09 PM   #1 (permalink)
Main Motorcycle: 08 T100
Other Motorcycle: 69 BSA Thunderbolt
New Battery
Want to order a new battery for my Carbed 08 T100 and was wondering if I would have any trouble fitting the yxt 14-bs, with its slight difference in hight, in place of the yxt 12-bs. Has anyone done this? just woried about the seat rubbing it?
jimham is offline   Reply With Quote
Old 01-12-2013, 03:24 PM   #2 (permalink)
Main Motorcycle: 01 Bonneville
Other Motorcycle: 796 Hyper
You may be the first. Suggest taping what ever scrap material you have to simulate the new height and let us know the results.
Mike
DBMike is offline   Reply With Quote
Old 01-12-2013, 03:40 PM   #3 (permalink)
Mike
Thanks Mike never thought of that "Duh" just would like the more cold cranking amps the 14 offers.
Old 01-12-2013, 03:45 PM   #4 (permalink)
Legend
Forchetto's Avatar
Standard battery is a YTX12-BS.
The YTX14-BS is 15mm (0.6") taller, you might be able to fit it if there's enough seat/battery clearance.
DBmike's suggestion is good. Find a slab of polystyrene or something 15mm thick and check clearance. Also check to see that the cables will reach the terminals.
Old 01-12-2013, 04:30 PM   #5 (permalink)
Main Motorcycle: I can't decide!
Hypurone's Avatar
Other Motorcycle: Ducati Monster S4RS
Or get a Shorai, save 10lbs, get extra cranking power, know that it fits (I'm your proof) and call it a day!
I am running 2 sizes larger (I have a hi-comp engine) and it still weighs 9 lbs less with plenty of space...
The price isn't for the faint of heart tho.
Chuck
'10 Thruxton 944cc - In the Faster Color
"Ridin' It Like I Stole It"
Hypurone is offline   Reply With Quote
Old 01-12-2013, 05:09 PM   #6 (permalink)
Main Motorcycle: 05 Bonneville
zeiset777's Avatar
Other Motorcycle: 1974 Kawasaki KS 125
I'm confused here, what does a lighter battery have to do with cranking power?
There's no way my ytx12-bs even weights 9 lbs. Maybe 5 or 6
zeiset777 is online now   Reply With Quote
Old 01-12-2013, 05:36 PM   #7 (permalink)
Hypurone's Avatar
The two have nothing to do with each other. But why not remove weight whenever possible? I was eluding to the fact he could go up 2 battery sizes, increase the cranking power AND still remove some weight from the bike. Plus he would know that they fit as I have done it.
The ytx12-bs that I took out of my Thrux weighed 10lbs! The new Shorai with higher reserve and CCA weighs 2.31!
Chuck
Old 01-12-2013, 07:07 PM   #8 (permalink)
Thanks Guys, I put a piece 3/4 " lumber beneath the stock ytx 12-bs battery and it was just a wee bit tight but was still able to refit the seat. But again that is 0.75" as oposed to 0.6" and had plenty of reach in the cables. I believe if I mount the cables to the face of the posts as opposed to the top like they are now I will have the clearence I need. Are 20 more cca really worth it. The cost difference is like 2-bucks, I think on amazon
Old 01-12-2013, 10:18 PM   #9 (permalink)
El Moderatore
Main Motorcycle: 2007 Bonneville LeMans
Calliway's Avatar
Other Motorcycle: 1972 CB350
Extra Motorcycle: 1977 GS400
Its a good way to get yourself stranded as the rubbing and pressure on the terminals will eventually break them on the inside of the battery.
Calliway is offline   Reply With Quote
Old 01-13-2013, 07:19 AM   #10 (permalink)
Main Motorcycle: 09 Sprint ST ABS
Billbikes's Avatar
Other Motorcycle: Lemond Zurich
When you're testing to see if the seat still fits, make sure you sit on it, and take into account flex when riding over bumps....
09 Sprint ST-Trident exhaust,rear fender tidy.
You can take the boy out of Texas, but you can't take Texas out of the boy.
Billbikes is online now   Reply With Quote
Battery Box delete and install of Shorai Battery on my 07 Thruxton SouthofHeaven Club Cafe' 29 10-17-2011 08:09 PM
Battery tender kills battery? oldretrorider Twins Talk 18 03-12-2010 12:46 PM
Car battery charger for MC battery? jonathanrsr Hinckley Classic Triples 7 03-02-2010 07:52 AM
Installing the Battery Tender lead to the battery msrtex Twins Technical Talk 4 01-13-2010 09:04 AM
Battery dead - Battery Tender flashing red BerkBon Twins Technical Talk 9 10-30-2009 05:33 PM
