12-25-2012, 04:33 PM
#21 (permalink)
Originally Posted by jkmolt
...properly mapped EFI can be far superior to most carbs...
Karl
Fixed it for you
12-26-2012, 08:34 PM
#22 (permalink)
Powerbike Main Motorcycle: '03 Bonneville T100
Posts: 302 Other Motorcycle: 74 Honda 450 long gone
Check out the thread where the salesman tried to trash talk carbs. Look at the responses from both sides. Technology is great until it doesn't work. Ever have your smartphone crash or come up dead or with no bars? When is the last time a landline did that? Your E reader is nice, but a book only needs light enough to see the words to work.
Sometimes it just beez thata way. AI,snorkel off, 18 primary, BC Sleepers, 42 pilots, Thrux nedles, 140 mains, K&N, NB bullets and tail light, BSA rear reflector OEM fly screen, knurled idle screws, air box bafflectomy, Barnett greens
12-26-2012, 09:47 PM
#23 (permalink)
SuperBike Main Motorcycle: 04 Thruxton
Posts: 1,431 Other Motorcycle: 13 Str Trple R
...EFI takes the human element out of it.
Karl
I am not sure of this is a good thing or bad...
2004 Thrux, FCR39's, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin Gunfighter, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, dropped forks
12-26-2012, 10:33 PM
#24 (permalink)
Formula Extreme Main Motorcycle: '02 Bonneville (100 year)
Posts: 786 Other Motorcycle: '06 S2R 1000
Originally Posted by BonnieBlack
In a blind taste test, I don't think most could tell the difference between the two tanks
Originally Posted by Johnnystriple
I checked out the side by side comparisons of the tanks and yea there is noticeable difference in size. That being said I think you would hard pressed to discern the difference when they aren't very close other than the slight ridge down the center of the carbbed tank.
Dog and I did a side by side taste test, (he brought it up), and though we weren't blind at the time  , he remarked how svelte the carbed tank looks side by side with the EFI, and I had to agree.
Other than that, the best thing that can be said about carbed Bonnes is they usually work so well you forget you don't have all the mod cons.
12-27-2012, 10:16 AM
#25 (permalink)
Grand Prix 500 Main Motorcycle: 2012 Thruxton
Posts: 149 Other Motorcycle: 71 CB350 Extra Motorcycle: 74 TS50
Its kind of like dare I say an oil discussion. Both have thier pros and cons and it comes down to personal preference. I like my EFI because it runs a lot smoother during large elevation gains in the mountains here but I also have carbed bikes and they are just as fun.
12-27-2012, 10:46 AM
#26 (permalink)
SuperStock Main Motorcycle: thruxton
Its far easier to tune EFI than carbs. Its quicker too as nothing needs to be dismantled for trial and error. If you can send an email you can load up a new map on your bike. The advent of free software has made F.I tuning as cheap, if not cheaper than carbs. Rejets, balancing and adjusting carbs take a certain level of mechanical skill to get right.
I came from a background of FI tuning turbo cars, I feel just as connected to my machine doing that as I do rebuilding carbs. Theres something satisfying about seeing the diagnosis displays on a screen, its like you are a surgeon and you are monitoring the bikes vital signs. It becomes a living breathing thing.
EFI will just be a nightmare if things start going wrong as new ECUs and injectors arent cheap.
After running a fair few of both carb'd and EFI bikes there isnt a fag papers difference between them.
12-27-2012, 01:19 PM
#27 (permalink)
Formula Extreme Main Motorcycle: Triumph Street Triple
Posts: 549 Other Motorcycle: 2012 Bonneville Standard Extra Motorcycle: 2008 Harley Street Glide
I guess with the right paint scheme you could make the EFI tank look a little slimmer.
12-28-2012, 01:45 PM
#28 (permalink)
Site Supporter Pole Position Main Motorcycle: 2008 Bonneville Black
Posts: 3,467 Other Motorcycle: Spousal 2009 Bonnie Black
Here's a comparison of the tanks, carbed vs EFI:
Side-by-side I'm sure you can tell the difference if you take the time to notice, but it's a small difference IMO. I'd think that if most people were just handed a tank, they'd have a hard time telling which kind it was based on size alone.
I used to be disgusted, but now I try to be amused.
"A fella could pretty much eat his car keys, if they were deep-fried". Billy
12-28-2012, 04:06 PM
#29 (permalink)
SuperBike Main Motorcycle: Triumph Thruxton EFi
Posts: 1,661 Other Motorcycle: Yamaha R1, Honda CB1000R
The second one meets the seat and the headstock better so I'll have that, which is it?
I have an EFi Thruxton and the tank is too small, I can't grip it under braking like I can with my R1 but I guess that's something you have to live with in the name of style.
12-28-2012, 04:53 PM
#30 (permalink)
2007 top, 2010 bottom. Metal vs Plastic badges give it away.
Do you have the knee pads on your Thrux? I have them on my Bonnie, and when I ride my wife's w/out them I notice the difference. Not that it's anything I wouldn't get used to, but they do seem to help. Aesthetically they probably don't fit the Thrux as well though.
