Rear Set Opinion - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-18-2012, 01:54 AM   #11 (permalink)
Main Motorcycle: 04 cafed Bonnie
ozbon's Avatar
Location: Toowoomba Queensland Australia (soggy bottom)
Extra Motorcycle: Two '68 Benelli 350's
I got a set of these from ebay for my '68 Benelli 350. The only problem is I need a folding footpeg to give clearance for the Benelli kick start. So I'll swap my Raask rearsets off the bonnie for these which will bolt straight onto the Raask mounting plate
Google Acacia Vintage Motorcycles
Ebay link below vv
http://www.ebay.com/sch/i.html?_odkw...0063&_from=R40
"Yeah, look.....Baz just vanished, like a.....fart in a fan factory, ya`know?! ".
Daz, the cane toad.
ozbon is offline   Reply With Quote
Old 12-18-2012, 06:07 AM   #12 (permalink)
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
I've used the Norman Hyde rearsets since they were introduced in '03. I find them to be sturdy and comfortable. NH customer service has been top-drawer.
Old 12-18-2012, 03:39 PM   #13 (permalink)
405
Main Motorcycle: Triumph
i agree, you certainly do get what you pay for with NH, their customer service has been great with me as well.
405 is offline   Reply With Quote
Old 12-18-2012, 05:40 PM   #14 (permalink)
DezynGuy's Avatar
Other Motorcycle: 2007 Tiger
Norman Hyde rear sets on order!
"I live for myself and I answer to nobody." -- Steve McQueen
DezynGuy is offline   Reply With Quote
Old 12-24-2012, 04:21 PM   #15 (permalink)
Main Motorcycle: 07 Bonnie
BonnieSquid's Avatar
I was on the fence about the LSL or the NH's, but after reading this I'm definitely thinking NH is the way to go. I'm also thinking about the M bars too.
There are very few personal problems that cannot be solved through a suitable application of high explosives
BonnieSquid is offline   Reply With Quote
Old 12-24-2012, 06:59 PM   #16 (permalink)
Main Motorcycle: 04 Thruxton
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
I am looking for rearsets for my Thruxton. Having bent my foot brake lever in the past, I am looking for a solution that retains the use of the OEM gear and brake levers. This may not be possible for the Bonnies. In the event I bend a lever, I can buy the replacement parts seperately. Otherwise if you bend an aftermarket lever then there is little option but to buy another complete rearset.
2004 Thrux, FCR39's, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin Gunfighter, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, dropped forks
Aussiematt is online now   Reply With Quote
Old 01-05-2013, 08:51 AM   #17 (permalink)
Main Motorcycle: Thruxton
Kapyong's Avatar
I purchased a set of LSL Rear sets for my Thruxton and they look to goods except that you need to retain the OEM mounts which takes away from the aesthetics however I find them pretty functional.
Downside is that the pegs are not spring loaded therefore if they are raised for any reason you need to physically pop them back into place. I have had two instances at the track where the right peg has hit the tarmac, kicked my boot off the peg and remained in the upright position, not good on the track!
For normal road use I have not had any issues with the LSL’s.
However after my last episode at the track where I could not return my right foot back to the peg I have ordered a set of Discacciati Thruxton Cup rearsets which are still in the post. Looking at the website, the rearsets are set further rearwards and higher, which is what I need for track work.
Attached is a pic of the current LSL’s fitted to my Thrux.
Kapyong is offline   Reply With Quote
Old 01-07-2013, 08:40 PM   #18 (permalink)
Main Motorcycle: '07 Bonneville T100
zenbike's Avatar
Other Motorcycle: '01 Sprint RS
Just installed a set of NH rearsets last week on my T100. I have to say with the NH M-bars (upside down) and Thruxton length shocks the bike feels totally transformed. Much more forward and aggressive feeling. I can notice the change in turn-in and handling with the taller shocks. The rearsets and M-bars are a great combination.
I rode around for a few days with the rearsets and bars but not the longer shocks and was not as impressed with the changes. Adding the shocks seemed to pull the whole package together and made it feel as I felt it should. I'm 6'-2" so the added height feels much better to me.
I'm happy with the upgrade and the way it makes the bike feel, however I have 2 critiques of the NH rearsets.
1: I wish they could have found a way to get rid of the stock mounting brackets. Feels a bit clunky to just bolt the new one over the old one. Once its all mounted the layman won't notice the extra brackets, but I do.
2: The shifting feels a bit loose. There is a little play in the pedal before the lever is engaged, wish it was a little tighter. You will have to move your foot farther up and down to shift vs. the stock set-up. But that is just a product of the linkage vs. the direct attachment of the stock system.
zenbike is offline   Reply With Quote
Old 01-08-2013, 11:05 AM   #19 (permalink)
Main Motorcycle: I can't decide!
Hypurone's Avatar
Other Motorcycle: Ducati Monster S4RS
Originally Posted by DezynGuy View Post
Now...if this only came in black...
http://www.bellacorse.com/bcc010.htm
Uh, Plasti Dip? Just did my tank badges and upper forks with the stuff. Comes out all wacky but sets up and dries nicely....
Chuck
'10 Thruxton 944cc - In the Faster Color
"Ridin' It Like I Stole It"
Hypurone is offline   Reply With Quote
Old 01-08-2013, 04:39 PM   #20 (permalink)
DezynGuy's Avatar
+1 with zenbike's observation #2. the shifter is a bit "softer" and the angle now requires more of a "toe point" - however, after a couple of days of adapting, it's a no-brainer and becomes second nature.
I'm very pleased with the outcome.
I need an opinion on a Used TBS Locolako Hinckley Classic Triples 30 06-03-2012 04:26 PM
opinion please StevenAB Twins Talk 15 05-20-2010 06:09 PM
Opinion on TOR daninplymouth Sprint Forum 28 05-14-2010 02:15 PM
Hi Need your opinion Cloudwalker The Welcome Center 1 05-07-2010 10:50 AM
opinion killian101 Twins Talk 16 05-01-2008 01:03 AM
