after reading a lot of info the general conclusion is a belt uses less power, but whatever since i installed it for lo maintain, cleanliness and long wear. on my sportster with wire wheels they only get dusty, adj are rare after break in even with the old tech belt, scootworks carbon fiber-kevlar belt thats a few mm wider than a chain, very few, only needs o adjust after break-in 2-4 thousand miles, harley belts usually go 50-100 thousand miles, for me the clean wheel and tire sells it if i only get 50,000 i would buy it again, yes $579 for a belt + sprockets is expensive but comparing several chain + sprocket changes, especially with labor if you do not do it is not a bad option in the long run, on my 70 bonnie i was forever at the high pressure car wash mostly for the rear wheel, but chain lube has improved for sure, the PITA is not for ME i love a clean shiny ride!!!
