Sprocket 19 V 18 tooth - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 12-06-2012, 05:47 AM   #11 (permalink)
GDM
Main Motorcycle: Bonneville Modified 2005
Other Motorcycle: Bonneville T100 2006
Extra Motorcycle: Honda CB900F BolD'or 1982
You can get a 19 tooth from Tec Bike part on ebay in Australia for $18 posted and very good quality .
GDM is offline   Reply With Quote
Old 12-06-2012, 05:11 PM   #12 (permalink)
Main Motorcycle: Triumph Street Triple
Johnnystriple's Avatar
Other Motorcycle: 2012 Bonneville Standard
Extra Motorcycle: 2008 Harley Street Glide
Question: I have a 19 tooth sprocket that I took of my 72 Bonny. Will it fit my '12 Bonny?
Johnnystriple is offline   Reply With Quote
Old 12-06-2012, 05:14 PM   #13 (permalink)
Main Motorcycle: 04 Thruxton
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
19T is good for highway work but not if you are running up and down mountain curves. I missed the low down grunt out of corners so switched back to 18T
2004 Thrux, FCR39's, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin Gunfighter, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, dropped forks
Aussiematt is offline   Reply With Quote
Old 12-06-2012, 06:28 PM   #14 (permalink)
Main Motorcycle: Triumph Scrambler
Other Motorcycle: Harley Dyna
Extra Motorcycle: Royal Enfield 350cc
put an order with BC...
I needed it urgently and cant wait to get from other side of atlantic
shrini23 is offline   Reply With Quote
Old 12-06-2012, 06:57 PM   #15 (permalink)
Main Motorcycle: '06 T100
road dog's Avatar
Tried a 19T on my '06 T100. It did reduce RPMs on the highway, but wasn't worth the trade off IMO. Had to feather the clutch a little longer to get going, and lost a lot of engine breaking when slowing. Came to the conclusion that stock was the best all around set-up, and went back to the stock sprocket in fairly short order. YMMV.
road dog is offline   Reply With Quote
Old 12-06-2012, 08:48 PM   #16 (permalink)
Main Motorcycle: 2007 T100
Nothing from the '72 will fit the '12. You even have to use '12 air in the tires.
larrykahn is online now   Reply With Quote
Old 12-06-2012, 10:32 PM   #17 (permalink)
Main Motorcycle: 2010 Thruxton
I'd wager that I had more top end with my 17T vs my 18T. I can certainly get up to license loosing territory faster with the 17T.
Did a 2400km tour in 4 days running the 17T and Preds, was awesome.
Jayc is offline   Reply With Quote
Old 12-06-2012, 10:41 PM   #18 (permalink)
Main Motorcycle: '10 Thruxton
Changing to 19T has been the best mod I've done so far... makes the bike run like I always imagined a Triumph would. The clutch slip issue is something I forgot about after the first stop sign. I was surprised at the loss of engine braking on my first trip in the mountains, but again, easily adapted to. Highway riding at speed is more comfortable. The twin makes lots of torque and the 19T change does not make the bike a slug.
Whathethrux is online now   Reply With Quote
Old 12-06-2012, 11:20 PM   #19 (permalink)
DezynGuy's Avatar
Other Motorcycle: 2007 Tiger
Originally Posted by denbow View Post
With a 19 T you'll be 3380 rpm @ 60mph, 3940 @ 70 and 4500 @ 80mph in 5th gear according to the chart.
I ran 17, 18 and opted for the 19 for its relaxed cruising speed and slightly better fuel consumption. It also stopped me feeling for another gear at 50 mph.
No noticeable lack of acceleration detected...just hang onto each gear a bit longer.
"I live for myself and I answer to nobody." -- Steve McQueen
DezynGuy is offline   Reply With Quote
Old 12-07-2012, 07:06 AM   #20 (permalink)
Main Motorcycle: The one I'm on, mostly.
Originally Posted by klem View Post
I have a Triumph T100 Bonneville with an 18 tooth front sprocket Im thinking about replacing it with a 19 tooth sprocket is there any reduction in engine revs at cruise speed with the 19 tooth and if so how much would it be if any?
Cheers Klem.
It depends on your Bonneville. If you have an electronic speedo vs. one driven by a cable to the front wheel, you won't see any difference because the electronic speedo reads off the transmission and that comes before the countershaft sprocket.
I tried a 17 tooth, an 18 tooth, and a 19 tooth on my 2010 T100 and I run about 4200 rpm at an indicated 70mph (113kph) with all three. The difference is that when I checked my speed with a GPS, it shows about 65mph (105kph) with the 17 tooth, about 68mph (109kph) with the 18 tooth and 70mph (113kph) with the 19 tooth.
The 17 tooth was kind of fun, but I'll probably go back to the 18 tooth. Also, I think the rubber on the Triumph sprokets is a plus.
Regards, Chuck
Charles Lathe is online now   Reply With Quote
19 tooth sprocket sonicboom Twins Technical Talk 25 12-04-2011 10:57 AM
Thruxton - 16 tooth or 17 tooth front sprocket? bpbrownengineer Club Cafe' 17 11-27-2011 02:39 PM
19 tooth sprocket crabby Twins Technical Talk 5 08-28-2009 08:03 PM
18 or 19 tooth sprocket ajf Twins Talk 34 03-31-2007 07:16 PM
