Carb troubleshooting - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-04-2012, 12:50 AM   #11 (permalink)
Askari's Avatar
is there fuel.
Undo the carb drain see if any fuel comes out. Look for a kinked pipe! When i fitted my fcrs. Iran out of fuel pushed the sucker 4 kms to the station to fit in only 10 litres! Issue a kink cutting off flow.
Askari is offline   Reply With Quote
Old 12-06-2012, 03:23 PM   #12 (permalink)
Main Motorcycle: 2008 Bonneville
eric nyc's Avatar
So since this all happened I've ridden the bike a good 50+ miles with no problems whatsoever. Since I didn't really address anything with any of the hoses it would seem a kinked hose wasn't the problem. If I had to guess, I'd say maybe there was a piece of sediment plugging up the fuel line somewhere and either through just giving it time to dissolve or repeatedly restarting the engine with the choke engaged I managed to flush it out. Still, the whole thing makes me nervous. I ride a lot across the bridges here in NYC and anyone whose been on them knows they are long, have no shoulders, few lights, and people fly over them at 70-80 mph pretty routinely. If what had happened last weekend had happened to me 5 minutes earlier, I would have stalled out in the middle of the inside lane of the Williamsburg bridge, which would have been virtually impossible to push the bike off of and incredibly dangerous with cabs and other reckless vehicles flying through almost blindly. Still, it's hard to take the bike into the shop and say "It was doing this thing a week ago but isn't doing it at all anymore. Fix it." Should I be concerned or does this sound like a fluke?
eric nyc is offline   Reply With Quote
Old 12-06-2012, 03:58 PM   #13 (permalink)
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
Perhaps you should put some injector cleaner in your fuel. Techron and Seafoam are great at flushing out impurities or varnish that may have afflicted your fuel system (it works great for EFI or carbs). It will stabilize your fuel, also; preventing condensate from pooling in the bottom of your tank or float bowls.
Old 12-06-2012, 08:22 PM   #14 (permalink)
Main Motorcycle: European Bikes
tooblekain's Avatar
Other Motorcycle: 2006 Triumph Daytona 675
Extra Motorcycle: 2007 Triumph Bonneville
This link will explain diagnosing carb problems. It has helped me immensely...hopefully it helps you too:
http://www.factorypro.com/tech_tunin...m_engines.html
tooblekain is offline   Reply With Quote
Troubleshooting low rev hesitation. pete312 Hinckley Classic Triples 25 07-23-2012 11:44 PM
Troubleshooting my 67 T120R WutUpCuuuz Twins Technical Talk 0 03-17-2012 05:39 PM
t509 troubleshooting! ag04 Speed Triple Forum 64 12-31-2010 06:44 AM
troubleshooting chrisjames Triumph SuperSports 5 09-12-2008 06:10 PM
Troubleshooting help? TT600n00b Triumph SuperSports 9 09-21-2007 10:08 AM
