Agh...broken clutch lever - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Old 12-02-2012, 09:49 PM   #1 (permalink)
Main Motorcycle: 09 Bonneville SE
Kito's Avatar
Other Motorcycle: I wish
Dropped the bike in a parking lot today (backing onto a speed bump and lost my balance), only real damage is the broken clutch lever. How much and how easy to replace??
Also noticed the indent on the primary case where the gear lever dug into it but it still changes gear ok. I had read of some problems from a bent shaft in these situations. I guess I was lucky. Watch out when you're backing!
Kito is offline   Reply With Quote
Old 12-02-2012, 10:31 PM   #2 (permalink)
Main Motorcycle: Scrambler
Other Motorcycle: Vespa P200
Well, when I dropped mine because I didn't put the stand down, (feel better about the speed bump drop now?) I just hit up ebay and got a replacement for about $25 or so. I had to replace my shifter as well, and that was another $25ish.
Edit: They're really easy to replace. It took me about 15 minutes, and only that long because I didn't notice the little bushing that needed to be moved from my old lever to the new one.
potato_peeler is online now   Reply With Quote
Old 12-03-2012, 08:47 AM   #3 (permalink)
Kito's Avatar
Thanks potato-peeler.
Old 12-03-2012, 01:26 PM   #4 (permalink)
Main Motorcycle: 2009 Bonnie EFI
TX1911fan's Avatar
I have a stock lever I can sell. Shoot me a PM.
TX1911fan is offline   Reply With Quote
Old 12-03-2012, 04:28 PM   #5 (permalink)
What about those cheap cnc'd units that everyone is buying on ebay these days?
luckyduck is online now   Reply With Quote
Old 12-03-2012, 10:32 PM   #6 (permalink)
Main Motorcycle: 07 Bonne Black
ovni's Avatar
Location: Mississippi Gulf Coast now Monterey, California
Kito,
I've got a very good one left from my parts post in the classified section. PM me and I'll send a pic. These are too easy to replace, btw.
07 Bonne Black with ARK, AI removed, K&N Pods, Nology Coil and wires, D&D full exhaust, 135 mains/42 pilots, 1 shim @ sea level. Biltwell trackers, Hagon 2810's & progressive fork springs. all blacked out.
ovni is offline   Reply With Quote
Old 12-03-2012, 10:46 PM   #7 (permalink)
Main Motorcycle: 2010 Bonnie Black MAG
BrewDudeBob's Avatar
Other Motorcycle: Dreaming of an Explorer
Extra Motorcycle: Dreaming of a KTM
Do this until you get a new one:
ΜΟΛΩΝ ΛΑΒΕ
BrewDudeBob is offline   Reply With Quote
Old 12-03-2012, 11:20 PM   #8 (permalink)
Main Motorcycle: Norton Commando
I did the same thing, dropped mine and put a longer bolt in the gear shift place as the picture above shows.
In fact I liked how much easier my foot could operate the shift lever with the longer bolt that I put the original rubber piece over the longer bolt with some small washers to locate it and have it in place ever since.
norton828 is offline   Reply With Quote
Broken Clutch Lever sfb Twins Technical Talk 15 08-23-2011 12:54 AM
Broken clutch lever R.Cooney Cruisers - America, Speedmaster 2 08-15-2009 02:10 PM
broken clutch lever silverfox Twins Talk 4 09-20-2006 01:09 PM
Broken Clutch Lever! Kravr36 Speed Triple Forum 7 07-23-2006 04:53 PM
Broken brake or clutch lever? welshrob Tiger Chat 0 06-02-2005 05:45 AM
