12-02-2012, 05:11 PM
Formula Extreme Main Motorcycle: '01 Triumph Bonneville
Alternative to stock or Oberon footpegs: LSL footpegs and brackets
Had to lay down my bike today. Not a big deal but I did break off the front brake-side footpeg.
Now I'm on the hunt for options. I don't want to go the stock or Oberon route. Why? Because of stories that the stud in the u-joint bracket breaks down the line especially if you've dropped or laid the bike down.
So, I've found an alternative: LSL Fold-up brackets and footpegs. They don't cost much more than a set of Oberons and you get to replace the whole u-joint assembly which is a plus.
Take a look at tell me what you think:
http://www.spieglerusa.com/fold-up-bracket-5431.htm
http://www.spieglerusa.com/controls/...-brackets.html
http://www.spieglerusa.com/controls/foot-pegs.html
12-03-2012, 04:55 PM
I've got these on order. I'll report back once installed.
12-03-2012, 06:11 PM
Site Supporter Team Owner Main Motorcycle: 2003 Bonnie
Posts: 4,762 Other Motorcycle: 2003 Speed Triple 955i Extra Motorcycle: Monkeybike!
Those look very smart... Let us know how you get on with them!
If knowledge can create problems, it is not through ignorance that we can solve them.
Isaac Asimov
Formula Extreme Main Motorcycle: 2009 Bonnie EFI
I have these and really like them. However, from what I understand, it is not the peg or the bracket that fails, but the cleat that attaches it all to the bike frame. That is not what you are replacing. You'll like the LSLs though. They are much more streamlined.
12-03-2012, 07:28 PM
Supersport 600 Main Motorcycle: 2005 Black Bonneville
Posts: 166 Other Motorcycle: 83 750 Midnight Maxim
I just put on adjustable LSL rear pegs, I really like them and plan to have front pegs as well when money is available
The Procrastinating Paramedic
12-04-2012, 04:09 PM
This was not my understanding from reading the various threads. You are saying the large chunk of mild steel that attaches to the frame is what is failing? I saw picture of primarily the welded stud in the clovis u-joint failing.
12-04-2012, 06:01 PM
I thought it was the clovis that was failing, which is the piece that attaches directly to the bike and to which the footpeg bracket attaches. When you get the new pegs, you get a bracket with holes that line up with the clovis holes and then you screw your pegs to that bracket.
12-04-2012, 08:22 PM
Team Owner Main Motorcycle: '06 T100
Most that have had a break report the clevis mounting stud sheared off. A few have experienced the casting of the actual peg breaking. Usually after a drop.
http://www.triumphrat.net/twins-tech...ml#post2413042
Personally I've not seen either problem firsthand. 6.5 yrs, 27K+ miles, calorie challenged, and like to stand on my Oberon pegs for a number of reasons. I believe it's a relatively uncommon failure, but it is a serious problem that gets lots of attention when it does happen... and deservingly so.
12-05-2012, 07:59 AM
World SuperBike Main Motorcycle: 1995 Daytona 1200
Posts: 2,205 Other Motorcycle: 1979 T140E, '06 Scrambler Extra Motorcycle: 851 Sprbk, YZF R-1, SV650
Originally Posted by luckyduck
Had to lay down my bike today.... l
I'm sorry for you misfortune but that phrase is genuinely hilarious.
12-05-2012, 09:56 AM
Maybe his garage door got stuck 3 feet open, and he had to lay down his bike to slide it out? Or maybe he wanted to take a photo of the sump bolt, and his camera wouldn't fit under the bike?
Otherwise, I suspect it would be more accurate to say "I crashed". :-)
Isaac Asimov
