Is the stock Scrambler underpowered? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-30-2012, 07:58 PM   #1 (permalink)
Main Motorcycle: Situation vacant
mydogiszen's Avatar
Hi folks,
I'm still mulling over which bike I should buy. I have seen a nice Scrambler. I see that they are quite a bit less powerful than the SE or T100. Is it very noticeably different and is it a problem?
If it is too weedy, are there many mods to put the power back up to SE/T100 territory?
Also, do the Arrow pipes make it go faster, or are they there for the noise value alone?
All the best
Steve
mydogiszen is offline   Reply With Quote
Old 11-30-2012, 08:34 PM   #2 (permalink)
Main Motorcycle: 2006 Scrambler!
bikebits's Avatar
Other Motorcycle: BMW R1200RT
Originally Posted by mydogiszen View Post
Hi folks,
All the best
Steve
The Scrambler has less hp at the top end than the Bonnies but makes more torque lower down the rev range.
I saw a comparison test of the Scrambler and T100 within the past year (can't remember where) and the Scrambler's 0-60 time was a couple of tenths faster than the Bonnie, but had a lower top speed.
The jist of the test was that the Scrambler was maybe a bit more satisfying at lower speeds. I hesitated in buying a Scrambler for a couple of years mostly due to the stock horsepower listed on paper. I have absolutely no regrets and enjoy it as much or more than any bike I've owned.
Dave (Scrambler Trans-Labrador Blog here)
bikebits is offline   Reply With Quote
Old 11-30-2012, 08:50 PM   #3 (permalink)
Main Motorcycle: 1965 TR6SR
rmak's Avatar
Other Motorcycle: 2007 Scrambler
Quite a bit less powerful?! According to whom? I had a Bonneville and bought a Scrambler. In stock form the Bonnie reved faster but was less torquey than the Scram. As the old saying goes, you ride the torque and brag about the horsepower. Personally, I experienced many more similarities than differences in the two bikes. Neither are built to be high performance machines. However, you can do a lot with these engines to up the power if you are so inclined. That all depends on how much money, time and effort you want to spend.
I did a big bore, hotter cams, Zard exhaust and flatside carbs on my Scrambler. So yes, mine is not very "weedy". It is simply the most fun bike I've ever owned. Good luck with your choice. If you decide on a Scrambler I doubt if you will be disappointed.
rmak is offline   Reply With Quote
Old 11-30-2012, 09:42 PM   #4 (permalink)
Main Motorcycle: 2012 Triumph Scrambler
Easy10pins's Avatar
The Scrambler has plenty enough power to get you into trouble.
Everyone is fast in a straight line.
Easy10pins is online now   Reply With Quote
Old 11-30-2012, 09:49 PM   #5 (permalink)
rmak's Avatar
Great shot! Priceless.
Old 12-01-2012, 12:55 AM   #6 (permalink)
DrX
Main Motorcycle: 2008 bonneville black
DrX's Avatar
DrX is offline   Reply With Quote
Old 12-01-2012, 12:58 AM   #7 (permalink)
Main Motorcycle: 05 Bonneville Black
Llamacide's Avatar
Ha! Priceless!
Llamacide is online now   Reply With Quote
Old 12-01-2012, 02:46 AM   #8 (permalink)
Main Motorcycle: Aprilia Caponord
Other Motorcycle: 2006 Scrambler (sold)
Extra Motorcycle: 1995 Daytona 900 (sold)
Try test riding both the Scram and Bonnie back to back. When I did I found the Bonnie left me with a distinct feeling of 'meh', whereas the Scram I really enjoyed. So basically, no the Scrambler is not underpowered compared with the Bonnie - you would never notice it.
bobbo is offline   Reply With Quote
Old 12-01-2012, 01:05 PM   #9 (permalink)
Main Motorcycle: 03 T100
mikeinva's Avatar
The 270 motor feels more torquey but in truth it isnt more torquey.I dont know who tested and said a scram is quicker 0-60 that is out and out bs. Most guys that buy these bikes change some things on them any way so when all is said and done put the same cams and pipes on them and they will make about the same power.The 2 things that kill power on the scram are the high pipes that make a u-turn coming out the head and the stock pos cams.Besides for the crank timing both have the same parts inside the motor.The 270 is easyer to hook up on a dirt track do to the crank timing a 360 motor tends to give more wheel spin.
Old 12-01-2012, 11:34 PM   #10 (permalink)
sprouty115's Avatar
I remember reading it here: http://www.mcnews.com/mcn/model_eval...eScrambler.pdf
- Stephen
sprouty115 is offline   Reply With Quote
Is the touring underpowered? 2scotties The Rocket Science Forum 40 07-19-2012 05:59 AM
...underpowered version of an underpowered version GingeWHU Speed Triple Forum 11 11-08-2010 04:58 AM
Speedmaster/America underpowered? gunfighter Triumph, Models & Dealers 4 11-05-2006 04:40 PM
Underpowered 05 S3? drmuela Speed Triple Forum 8 06-11-2005 11:53 PM
