Newbie w/ 09 Bonneville with issues...HELP!! - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-30-2012, 04:22 PM   #21 (permalink)
Main Motorcycle: 09 Triumph Bonneville
Other Motorcycle: 08 Victory Hammer
Thanks for the encouraging comments!!! It energizes me!! I rode it some more today...I really like this bike a lot!! I rode the Hammer afterwards and man, that thing feels like a big ole' pig in comparison!!
My son was noticing that the chain was slightly looser than normal on the bike and the adjuster is maxed out. I had felt like the speedo was reading higher than actual mph. HMMM, something seems amiss!!! Hard to believe the chain would stretch that much in 8600 miles??!?! I GPS'd my actual mph vs. the speedo and i'm off around 10mph!! Put the two issues together and what do you have? It's not the rear sprocket, it is the stock 43 tooth. It's GOT to have a smaller front sprocket, which would solve both issues!! I will check soon, but that would be an easy fix if that is it!!
Originally Posted by RICHW View Post
You can take off the SAI (secondary air injection) hoses and hardware to run your pipes a bit cooler and have some extra power - plenty of posts on the forum showing how to do it.
I did the SAI mod today. I went with the electrical wire nut shoved into the hose and then zip tie on both side of that to ensure it doesn't make it's way in either direction. Thanks for the suggestion!! It seems to work great!!
I also have bought the following today from some of the members of this very fine site...
(EDIT: DISREGARD THIS PART, I ENDED UP FINDING THE RIGHT MIRRORS* Mirrors off 2009 Scramber. They look to be slightly different than the Bonnie ones I see listed (different angle?). Hopefully I can at least modify to work ok? http://www.triumphrat.net/attachment...t-p1010603.jpg
* Used mirror brackets as at least one of mine is toasty!!
* Used levers (one of mine is broke).
* New cam cover gasket.
A couple of decent leads on a front fender. But nothing to speak of for the headlight assembly/brackets and gas tank? Anyone has these or knows someone who does, let me know!?!!?!
2009 Bonneville
2008 Victory Hammer
1995 Honda 750 Nighthawk(my sons, but he's at college, so...)
1996 Mustang Cobra w/ Hellion Turbo
1997 Mustang Cobra w/ Kenne Bell supercharger
goat-ee is offline   Reply With Quote
Old 11-30-2012, 04:52 PM   #22 (permalink)
Main Motorcycle: '02 Bonneville (100 year)
steve betts's Avatar
Other Motorcycle: '06 S2R 1000
For $1900 I think you did great. I'm not a cruiser guy but I always thought those Hammers were pretty cool. Now please swap those mirrrors if you haven't already.
steve betts is offline   Reply With Quote
Old 11-30-2012, 05:10 PM   #23 (permalink)
See post just above yours!! lol
2009 Bonneville
2008 Victory Hammer
Old 11-30-2012, 05:15 PM   #24 (permalink)
I work 12 hours tonight and wasn't going to check today, but I couldn't stand it any longer, I had to know what the front sprocket is!!! It's an 18 tooth (not the stock 19 tooth). Any way to make the speedo read right? If so, I would just shorten the chain a link, because I do like the way the bike rides right now, but I can't stand the speedo to be wrong by that much.
2009 Bonneville
2008 Victory Hammer
Old 11-30-2012, 05:40 PM   #25 (permalink)
Main Motorcycle: 09 Bonneville Black
LittleJoe's Avatar
Other Motorcycle: 02 Ducati 748S
Extra Motorcycle: Kawi ZX-7R (trackbike)
Even with the correct CS sprocket, it will probably still read 10% high as opposed to 10mph.
LittleJoe is offline   Reply With Quote
Old 11-30-2012, 05:46 PM   #26 (permalink)
Main Motorcycle: '09 Bonneville SE
Other Motorcycle: X-75, in a basket
Extra Motorcycle: '73 Honda SL-100
You may have to live with the innacurate speedo, the '09 reads off the front wheel, so how the bike is geared has no bearing on how the speedo reads. They all read 10 - 15% fast, & I agree with you it's annoying, but in may case, for 4 seasons & 18,000 miles, that's the worst thing I can say about the bike. Also, I believe that 18/43 is stock gearing. My original chain is still fine, but I bet that the dude you bought the bike from never maintained it!
"A deluge of air, a tenth of a phantom of gas, two knots of velocity, & a modicum of spark"
kokbaba is online now   Reply With Quote
Old 11-30-2012, 06:03 PM   #27 (permalink)
I didn't even think about the speedo reading from the front wheel. I'm pretty sure I knew that somewhere deep in my head, but I always have a car brain!!!! (rear wheel drive) I was just researching here on the site and the 1st thread I saw said stock was 19, but it could be incorrect? Damn internet!!! Thanks for the info!!
2009 Bonneville
2008 Victory Hammer
Old 11-30-2012, 06:07 PM   #28 (permalink)
Main Motorcycle: 2008 T100
bluesforchallah's Avatar
http://www.ebay.com/itm/Triumph-t100...#ht_437wt_1200
http://www.ebay.com/itm/TRIUMPH-04-2...#ht_213wt_1400
Chris
BIR# 309
08 T100 with AI removed, K&N Pods, BC Predators, 150mains/45 pilots, no shim, -2.0 turns out @ sea level, green springs
bluesforchallah is online now   Reply With Quote
Old 12-01-2012, 09:53 AM   #29 (permalink)
Main Motorcycle: '08 T100
Other Motorcycle: N/A
I too believe that 18/43 is stock.
Rick
RickMcCl is offline   Reply With Quote
Old 12-01-2012, 10:20 AM   #30 (permalink)
Rick
Yes 100% right.
Plasma.
plasma is offline   Reply With Quote
07 Bonneville idle issues drJekyll Twins Technical Talk 30 06-26-2012 01:11 PM
1969 Bonneville Gas Cap Issues jva118 Classic, Vintage & Veteran 8 09-10-2009 07:29 PM
Newbie Issues zestymac Speed Triple Forum 6 06-05-2009 10:28 PM
Tire issues...questions from a newbie BinaryS4 Triumph SuperSports 20 07-20-2006 08:39 AM
'04 Bonneville Carb Issues.... speedrcr Twins Talk 6 03-23-2006 07:20 PM
