Time for a fixer upper - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-28-2012, 07:40 AM   #1 (permalink)
Main Motorcycle: Triumph Bonneville Black
Other Motorcycle: Suzuki GS500
So my beautiful Bonnie is a bit banged up, but nowhere near as bad as I was told.
First step a workbench to put it on. I can't bend over right now without head spins, so a quick call to a mate sorted that out. I did most of the sitting down and pointing, and he did most of the work.
We knocked this from bits in the shed.
'06 865 Carby Black Bonnie: Smashed gauge pod and tach, dented Madaz pipes. road adjusted Burleigh Bars, totally destroyed hand controls and rear brake system, bent footpeg bracket, dented tank, ripped seat, and torn cables.
Rageon is offline   Reply With Quote
Old 11-28-2012, 07:54 AM   #2 (permalink)
And here she is back home up on the bench.
I'm so lucky a mate got there first and whisked it away on his trailer.
The towy was pissed, and I saved $800
Old 11-28-2012, 08:53 AM   #3 (permalink)
Main Motorcycle: 2007 Thruxton Bonneville
Nickwiz's Avatar
Other Motorcycle: BSA Starfire 1968
Extra Motorcycle: 1930 Triumph NSD.
Looks rideable, whats broken?
Banged up is cool it shows you're riding the thing
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind......Dr Seuss
Nickwiz is offline   Reply With Quote
Old 11-28-2012, 03:20 PM   #4 (permalink)
It's not that bad actually. I've done some stocktaking, and have come up with the following.
Footpeg brackets bent inwards, these are cast, so it will be replacement OEM or CNC ones
Rear brake lever and master cylinder bent and seized.
Handlebars odd shaped, and all hand controls destroyed.
Instrument pod and Tacho mangled
Control cables torn/crushed.
Front and back brakes not working
Rear tail light assembly smashed.
All the oil is totally gone, this is a complete mystery to me as to where it went.
The rest of the stuff is cosmetic, Dents & scratches. Tank, Exhaust, ripped seat.
The footpegs and brake lever kept the sides off the road, but it looks like the whole bike scraped down the road totally upside down. not a scratch on the engine, frame or exhaust headers.
I have vague recollections of it spinning through the air down the road after me, and it landed right beside me when we came to a stop.
I have 5 more weeks till I can ride, so I may as well fill in my spare time.
Old 11-28-2012, 09:13 PM   #5 (permalink)
Main Motorcycle: '07 Black
Easy13's Avatar
If it was upside down, check your airbox for the missing oil. It shouldn't be too tough to get the bike back together and I'm glad you're at least functional: sounds like it could have been much worse.
"Cognito Ergo Wrenchum"
Easy13 is offline   Reply With Quote
Hello from Upper Austria Housedog The Welcome Center 0 05-31-2011 11:46 AM
Ebay fixer upper num1husker Sprint Forum 12 09-04-2007 09:44 PM
955 / 595 upper fairing yellerduck Daytona Deliberations 6 11-27-2006 12:37 AM
