BikeBandit
Old 01-12-2006   #1 (permalink)
Black Bonneville - Putting on the stainless hex screws to replace the pot metal Phillips. 1st problem is that the left inside back screw is not coming out and may be slightly stripped. I think I may need to remove the carburetors to get this sucker out. Any trick to removing the large rubber intake hoses? Seems to be the worst part. Problem #2 - I removed the bottom of the float bowl to see how the jets are located. Removed the main jet to see how difficult. Reassembled and now get a slight popping when the engine is idling or backs off. I am thinking that maybe the jet holder may have backed out a bit. Should this be tightened first and then the jet? Do I attack or punt it to a real mechanic. Thanks.
You've never rode until you've been throwed.
Anchorbend is offline   Reply With Quote
Old 01-12-2006   #2 (permalink)
That screw got me too. I ended up using a vise grips to loosen it--what a pain. There are several other methods I've seen posted here. One was to cut a new slot in the head--can't remember the others.
I made sure the jet holder was tight before tightening the jet.
Check out this website for some useful tips:
http://members.bluefrog.com/~pwhitbe...ph/carbs0.html
Good luck!
"In the end, it's all a gag" -Charlie Chaplin
Liontari is offline   Reply With Quote
Old 01-12-2006   #3 (permalink)
Favorite Bike: 2005 Bonneville T-100
Panthermark's Avatar
I had no intentions (or know how) when I removed my carbs....but the stupid stock carb screws forced me to do it.
pull em......
I had to use vice grips on a couple of the screws.....
For the couplers.....silicone spray....it softens up the rubber.
Mark
Old 01-12-2006   #4 (permalink)
Where's Daz when wer really need him?
bcohen is offline   Reply With Quote
Old 01-13-2006   #5 (permalink)
Sounds like you may have bent the float tang and changed the fuel level in the bowl.
have fun-ride often!
thruxtonone is offline   Reply With Quote
Old 01-13-2006   #6 (permalink)
Removing the crabs is really pretty easy. Remove seat and tank first. Loosen the clamps attaching the carbs to the rubber aintake manifolds. Disconnec the two wires to each carb. Remove the screws holding the battery box/air cleaner assembly in place, and slide it towards the rear of the bike - you should be able to move it one-hlaf inch without any difficulty. This will give you the space you need to wiggle the carbs free,. There is no need to disconnect the throttle linkage. Replace the soft brass screws and reassemble. Take your time and don't force anything. The entire process should not take more than 30 minutes.
Hard work may pay off some day, but laziness always pays off right now.
Bill
View my photo album
billstokes is offline   Reply With Quote
Old 01-13-2006   #7 (permalink)
Anchor,
I posted a reply over on the NTBF.. all the responses here are good info, especially T1's comment about possibly bending the float tang and changing the float level.
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 01-13-2006   #8 (permalink)
Thanks for the advice everybody. I do believe that bending the tab a fraction might have been possible so I will work on that. As far as the screw goes I will try the suggestions and keep my fingers crossed.
valve adjustment and Murphy's Law GeoDiablo Twins Technical Talk 30 02-11-2008 05:27 PM
St. Murphy's day ! Tbirdnz Biker Hang-Out 13 12-06-2007 12:03 AM
New Law for Motorcyclists in NC Bonnebret Twins Talk 11 12-04-2007 06:05 PM
New law in NC macstuf Biker Hang-Out 20 12-03-2007 05:56 PM
I fought the law and the... law won tealetm Speed Triple Forum 56 09-14-2006 04:07 PM
