Need HELP On TPUSA Powepack Install - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-17-2012, 07:55 AM   #1 (permalink)
Main Motorcycle: 2007 Triumph Thruxton
kjax909's Avatar
Other Motorcycle: 2002 BMW R1150R
Installed most of my carbs powerpack upgrade yesterday. Have remove all of the SAIS plumbing, but I can't tell what this is and whether it n eeds to come off as well. Seems like it should, but the hose coming out of the back goes to a hard plastic T-pipe between the carbs that can't be removed. If I remove it, do I need to cap off that T-pipe? If you click on the picture, you can see it better than this thumbnail. Thanks!
'07 Thruxton: Rox Speed 2" risers, 130w/90w headlight w/ relay, OEM tank pads, OEM fly screen, TPUSA carb powerpack special, Hagon nitro shocks, Progressive fork springs, "old style" fork gaitors, Napoleon mirrors, screw-in oil temp guage
kjax909 is offline   Reply With Quote
Old 11-17-2012, 12:41 PM   #2 (permalink)
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
The thumbnail didn't get any bigger.
Quentin
wenzel850 is offline   Reply With Quote
Old 11-17-2012, 01:06 PM   #3 (permalink)
Main Motorcycle: 08 Bonneville Black
ruger's Avatar
You should probably call or contact Carlos at TPUSA if you don't get any satisfaction here.
Ruger
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/TPUSA tach kit/520 kit,19T/Denalis/Bashplate/DEcosse MOSFET upgrade/More crud/Ruger's Garage
ruger is online now   Reply With Quote
Old 11-17-2012, 02:19 PM   #4 (permalink)
Legend
Forchetto's Avatar
Is it part of the California EVAP system?. See thread below concerning its removal. It's referred to as a "canisterectomy". Post 1 talks about that "T" piece and the following post is linked to a .pdf file with instructions from GaryD:
http://www.triumphrat.net/twins-tech...ss-bridge.html
Need HELP on TPUSA C arb Powerpack Install kjax909 Club Cafe' 4 11-17-2012 12:12 PM
tpusa cam doger5 Twins Technical Talk 24 10-13-2012 06:50 PM
TPUSA "Power Pack" install devildave Club Cafe' 0 07-09-2012 10:01 AM
865 TPUSA kit Askari Twins Technical Talk 3 10-18-2011 10:09 AM
D&D Vs TPUSA 904 Kit sharp21 Twins Technical Talk 10 10-08-2011 05:37 PM
