Pothole Damage - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 11-14-2012, 12:14 AM   #1 (permalink)
Main Motorcycle: BSA B31
Other Motorcycle: T100
Extra Motorcycle: R1200GS
Pothole Damage
Oooops.
The above picture is the result of hitting a pothole, was only doing about 35mph, front wheel was fine but after hitting the back wheel I was in fishtail, luckily no other traffic near. Tire is fine and there was no difflation so was able to ride home. Pothole was about 2 feet across and 10 inches deep, in 30+ years of riding Asia's roads this is the first poblem I've had with wheels.
The wheel appears to be fine apart from the obvious rim problem, spokes all feel ok, and the wheel runs true.
Looks like a relatively easy fix for a lead hammer and some wooden blocks. Anybody else had any experience at fixing such a problem?
Thanks.
deaninkl is offline   Reply With Quote
Old 11-14-2012, 10:12 AM   #2 (permalink)
Main Motorcycle: 2010 Scrambler
ScramblerKidd's Avatar
Repair... Your life is in your hands. I'd replace the rim,tire and spokes. Why risk it?
ScramblerKidd is offline   Reply With Quote
Old 11-14-2012, 10:29 AM   #3 (permalink)
Main Motorcycle: 06 bonneville hardtail
o4petesake's Avatar
Other Motorcycle: looking
replace
Tire may have unseen damage,i know everyone has to live within a budget but replace it.
o4petesake is offline   Reply With Quote
Old 11-14-2012, 11:51 AM   #4 (permalink)
Main Motorcycle: 2012 EFI Thruxton 900
Hotboppincat's Avatar
Other Motorcycle: Honda CBF 125 2011
If you did want to try to fix it (and I tend to agree with everybody else, replace the wheel and tire, and as a minimum I would at least replace the rim and tire), you will need to true that rim up SPOT ON, and then ensure there are no cracks in the metal....(microscopic cracks grow larger, the wheel is a stressful place)
A better option is to relace a rim to the hub.
Then you are going to need a dial gauge on a stand, with a magnetic base and a metal workbench to attach it to (or clamp the dial guage stand to the bench if you have a wooden one), and then you will need to adjust the spokes to get the whole wheel running true with a spoke spanner.
To true up a wheel I put a spindle through the wheel, put the spindle in the vice with the wheel horizontal, and offer the magnetic base dial gauge up to the rim.
This is not an easy job, but I have no idea how much experience in wheel building/maintenance you have. I had to be shown by an experienced mechanic. And I still struggle.
Hotboppincat is offline   Reply With Quote
Old 11-14-2012, 12:49 PM   #5 (permalink)
Main Motorcycle: 'Triumph Sprint Executive
Derswede's Avatar
Other Motorcycle: '95 Trident
Look for a wheel repair place....my brother fixes rims and it takes heat and precise bending to get the wheel back without cracking the metal or causing a failure point on the rim. He's seen too many rims (albeit on cars, not bikes) that failed later due to improper repairs. Esp. important on alloy rims...steel rims are not as fragile, but still can fail and leak.
Derswede
Common sense is dead. The wake is tomorrow.
Derswede is offline   Reply With Quote
Old 11-14-2012, 01:11 PM   #6 (permalink)
Well said.
Old 11-14-2012, 08:44 PM   #7 (permalink)
Thanks for the replys, I am looking for a wheel repair shop, but here in Malaysia they appear rare, I'm an engineer so rather than just give it to a bike repare shop who would almost certainly just bash it back into place, I'll take it apart and do it myself.
That's the short term, longer term I see new rims when I make my next trip to the US or Europe.
I'll let you know how it goes...
Old 11-15-2012, 12:08 AM   #8 (permalink)
Time for a wide wheel kit!
Old 11-15-2012, 12:36 AM   #9 (permalink)
That must have been some pot hole to do that amount of damage! And we think our roads in the UK are bad!!! Sorry if I sounded patronising, that was not the intention, if you are an engineer then the work is acheivable, but the original rim may still cause a risk in the future, as the other guys stated. My Uncle rebuilds classic bike wheels (he used to do it for a living, he had his own business), unfortunately I never mastered the art, but now I have a Thruxton with spokes, it looks like I will need to pay them some attention once in a while. Best of luck.
Old 11-15-2012, 12:42 AM   #10 (permalink)
Main Motorcycle: 2013 triumph bonneville
best wheel guy i have seen/heard is woodys wheelworks
http://www.woodyswheelworks.com/
ship him the wheel, if he can fix it properly, he will, if not, he'll give ya some options, he's fair, honest, and DAMN good
villageidiot327 is offline   Reply With Quote
The pothole and the damage done pauliewalnuts Twins Talk 17 09-25-2012 05:01 PM
Pothole "Killer" Joemomma Biker Hang-Out 24 04-16-2012 02:35 PM
3 in 1 damage from a get off ioneater Street Triple Forum 11 12-11-2010 07:41 PM
My Coocase snapped off when I hit a pothole today. Hatchetman240 Sprint Forum 22 03-24-2010 11:43 AM
jim dandy pothole got me fugitive Twins Technical Talk 3 09-26-2007 04:52 AM
