Yes, the lamp holders are attached to the sub-harness.
I'd try some heat-shrink wrap or tape around the rubber boot before spending that much on a new harness. Another possibility is to see if anyone who installed the Triumph tachometer kit will sell (or give) you the old sub-harness, as the tacho kit comes with a new one. Then you can clip off spare lamp holders as needed.
Marty
