Quickie carb cleaning question - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 11-12-2012, 07:58 PM   #1 (permalink)
Main Motorcycle: 2008 Bonneville
eric nyc's Avatar
So I've been doing some really hard riding in some areas with a ton if dust, sand, mud, and god knows what else over the last two weeks. My carbs are struggling. I basically have to run with the choke at at least 1/2 to even make a run right now. In the long term I know the air filter needs a change and the carbs probably need a thorough cleaning, but I grabbed some carb cleaning spray today and am trying to keep her running at least functionally for another 3-4 weeks before having a proper tuneup and teardown if necessary. Any suggestions?
eric nyc is offline   Reply With Quote
Old 11-13-2012, 05:57 AM   #2 (permalink)
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
if you have been riding in a filthy dusty area and you suspect the air cleaner is clogged, then just change it. only takes 10 minutes and unlikely dust would have passed through it into the carbs.
2007 B&W T100.
AI & Snorkel gone, Dom Tourers, 40/120/1 shim 3 turns, TTP stage one, Dart screen, Pingel fuel valve, Monza gas cap, Avon Roadriders, Triumph fabric saddle bags sometimes
I like a man who grins when he fights -
Winston Churchill
bonza is offline   Reply With Quote
Old 11-13-2012, 06:27 AM   #3 (permalink)
Main Motorcycle: 1995 Daytona 1200
SlowPocono's Avatar
Other Motorcycle: 1979 T140E, '06 Scrambler
Extra Motorcycle: 851 Sprbk, YZF R-1, SV650
If the choke is required to make it run right, I'd look for an air leak first.
Check the connection between the carb and intake manifold.
My guess is that there isn't anything wrong with the carbs.
SlowPocono is offline   Reply With Quote
Old 11-13-2012, 08:38 AM   #4 (permalink)
Main Motorcycle: 2012 T100
norton74's Avatar
Other Motorcycle: 2013 Rocket 3 Touring
Extra Motorcycle: '73 Ducati GT750
I agree with SlowPocono. Check for air leaks.
If the air filter was plugged, your bike would run rich. Using the choke would only make things worse.
norton74 is offline   Reply With Quote
Old 11-13-2012, 11:55 AM   #5 (permalink)
eric nyc's Avatar
I dropped it at the shop today to get a new tube for the rear tire and they're going to take a look at it.
Basically what's happening is it's taking a long time to warm up and when I throttle it, even in neutral, it sputters and stalls without the choke basically all the way out. Once I get it moving the problem seems to go away after about 5-10 minutes and I can close the choke. But even this morning getting it to the garage I almost couldn't get it moving so whatever the issue is it's getting worse with time. It started on Sunday, was a little worse yesterday, and much worse this morning. Hopefully the garage can sort it out - whatever this particular issue is, the air filter also needs to be replaced so they're going to go ahead and do that while they're working on it. But yeah, the fact that it needs a lot more choke than usual would seem to suggest that there's not a problem with not enough air getting to the carbs.
Old 11-13-2012, 11:59 AM   #6 (permalink)
Vacuum leak.
luckyduck is offline   Reply With Quote
Old 11-13-2012, 12:14 PM   #7 (permalink)
eric nyc's Avatar
Originally Posted by luckyduck View Post
Vacuum leak.
I had that thought, but then why would the problem go away as the bike warmed up? Wouldn't that be a constant problem?
Old 11-13-2012, 12:30 PM   #8 (permalink)
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
As the motor heats up, parts expand and reduce the leaks. My early Bonneville gave me fits with air leaks after pulling the carbs to rejet. I eventually took care of the problem with higher quality HD SS clamps for my intake boots. Place the boots/clamps carefully and avoid overtightening...
Old 11-13-2012, 01:01 PM   #9 (permalink)
eric nyc's Avatar
Just so we're talking about the same thing, are you suggesting there's a leak at the carb air intake? I was thinking it could be a cracked diaphragm in the carb itself.
Old 11-13-2012, 03:18 PM   #10 (permalink)
Sheepdog's Avatar
Either are possible...and I've experienced both. The spigots on the engine side of the carbs are not very wide. If you are not careful when you reconnect, the clamp can actually slip off of the spigot and create an opening that will allow air within. Get a mirror and check completely around the connection...all it takes is a small misalignment. Also, Ive had problems with the stock clamps pinching the manifold rubbers and creating a leak. Lastly, its easy to unseat the diaphram when replacing the tops on your carburetors. If unseated (or torn), an air leak WILL occur.
carb cleaning due? BlueTbird Hinckley Classic Triples 3 06-22-2011 10:13 PM
Help with carb cleaning... rwsollars Hinckley Classic Triples 13 10-11-2010 07:16 AM
carb cleaning question grez T3 Sport / Touring Forum 11 10-23-2009 12:10 AM
Quickie tire question ohiorider Twins Technical Talk 2 09-08-2007 07:25 AM
Carb Cleaning jimmyj900 Hinckley Classic Triples 3 05-21-2006 09:44 AM
